Question about Fisher and Paykel GWL11 Top Load Washer
Diagnostic lights If you carefully open the display panel cover, (do not pull it hard or far apart), there is a service summary brochure. This tells you how to do a diagnostic and some testing. My test showed the last wash cycle light on and the first rinse light on. Does any one have a service manual that could tell me what this means?
The spin light is 1 the next light is 2 going from right to left 1/2/4/8/16/32/64/128 so if spin light on and the first green light on in wash cycle you have a 1 and a 128 which equal 129 look on that sheet to see what it tells you all nubers are not on it though
Posted on Feb 28, 2009
'95 Lincoln town car. Husband was driving uphill and the digital dash suddenly went dark. Radio is working and a/c is not. Exterior light still working and so are interior lights besides the dash
Could be a bad wire possibly chaffing or grounding out to to another wire or frame. Check your fuses. You may want to pull the dash out and check that wiring as well
Jul 07, 2015 | Lincoln Cars & Trucks
Installed new door lock still have e27 error code
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You can manually release the latch by removing the lower panel (Torx fasteners, I think) and finding a wire lanyard that releases the latch. However, I had read that there was a diagnostic code that could be used to reset the latch solenoid via the control panel.
There is no service manual available on line, as far as I can tell.
Here is what worked...
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
Oct 15, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
How to open Sony remote RM-GD005
1 - Remove the battery cover and undo the two screws.
2 - On the front of the remote down the bottom there is a slider that covers some additional buttons. Slide that down then twist/lift/pull until it comes over. Be gentle.
3- Looking from the top, along each side, between the black front and the silver side pieces, push a small screwdriver in the join to open it up. Start at the bottom and work towards the top. There are a couple of plastic clips along the join and as you work up they will unclip. Once you have done one side you should be able to pull it apart fairly easily.
:) Chris
Jan 15, 2012 | Sony Televison & Video
Service engine light stays on. changed oil last week.
The service engine light does not refer to oil changes, it is used to check for engine fucntion and emmision control sensors. Most likely you have a fault in one of the emmission control sensors.
Dec 04, 2010 | 2003 Chevrolet S-10
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Need disassembly instructions
-After removing the plastic ends, remove the two other metal pieces that the plastic ends were attached to. -Turn monitor upside down and you will see two small tabs on each end. Just pull those outward. They don't move far, but that releases the bottom seam of the monitor. - Carefully pull the two pieces apart. Remember that you will put a crease on the front of you monitor if you open it too much. - If you have a tool to remove the power cable great, but if you don't you can carefully pull the cable through the hole. -Then the whole LCD with all the boards can be removed and serviced.
Mar 29, 2009 | Apple Cinema Display 23" HD Monitor
Fisher and Paykel EcoSmart GWL15 water will not drain out.How do you remove the pump to see if it is clogged ?
tilt the machine to get to the bottom and there is an electric pump that you can remove with no tools, you twist if out. after that is removed you should see what has clogged your pump.. I spent 4 hours disassembling my entire machine , cleaning it, trying to find out what was wrong. And the fix could of just taken me 1 minute.. Next time... But at least I know how to take everything apart now, very easy and simple machine to work on.
Mar 08, 2009 | Fisher Paykel EcoSmart GWL15
Lens cover stays in between, won't open nor close
Had a similar problem once. Fixed it by opening the camera and freeing up the lens cover.
1)Undo 2 screws each side and the base (6 in all) ignore the one on the front edge of the base for now.
2)Separate the base from the case (gently!) don't pull them too far apart, because they're joined by ribbon cables.
3)Then remove the long screw you ignored above, and again carefully separate the front panel.from the body.
4) At this point, you should be able to access the back of the lens cover, and free up the mechanism.
Once that' s done, put it back together, reversing the above sequence. Don't force anything, just make sure they're all lined up and fit before inserting the screws.
good luck.
May 09, 2008 | Fuji FinePix F401 Digital Camera
Keyboard removal
even after you have removed the screws the keyboard is still wedged on to the display panel just above it you have to actually unclip the display panel first and then only you would be able to remove the keyboard, gently because the keyboard would still be attack via cable to the mainboard.
Mar 11, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Fisher and Paykel GWL11 Top Load Washer Logo
259 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
