Question about NetGear RangeMax WPN824 Router
Router login? I am trying to setup my router for a new laptop and when using the software for installation I get through all the steps except it connects me to a web site and a window pops up asking for a secure router login. All of my passwords for this router were on my laptop that is now not working. I tried to use what i thought was the right password but the window will disappear and the website says 401 not able to open page because I did not enter the right password. How can I just set up my router on a new laptop.
  • 13,433 Answers
Hi
The details should be username:
admin
Password:
password
those are the defaults that read in the manual of rangemax wpn824
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
The router installs fine on one lap but I still can't connect my other laptop
your first option is to go to http://192.168.0.1 Here Select admin from the drop down menu and leave the password field Blank.
Once the page loads youll see a series of options. this is the routers linux interface section. you will see D-link on the top left.
Select the first option Install router.
the steps would be as follows.
Step 1.
Insert the Router Setup Wizard CD in the CD-ROM drive. follow The step by step instructions. Once you done this And i believe you have already. see step 2
Step 2.
Select the Option
Setup on the Top > Internet is on the left side.
Under the Internet connection Wizard Hit the Setup Wizard button.
Step 3.
Now on the Setup page Same place where the setup Wizaed is. just below their is another option called Wireless Security Setup Wizard.
Press the Launch Wireless Security Setup Wizard Button.
Read the 3 steps then click the next button to continue.
Steps for step 3.
1. Enter a SSid this will be the network name you see when you want to connect to your own network. example.. MyHome
2. Select your security option then click next. (For simplicity chose WEP)
3. click apply.and let the router reboot.
when it comes back online you should see your network you just setup. our example was MyHome.
If you are new to router setup. use the Wep security called Good on your routers security WEP. and just write the key it gives you down. this is the code you need to connect your devices and is considered ok for a simple home network.
Nov 22, 2011 | D-Link DIR-615 Wireless Router
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
I have been installing the router program step by step but when it comes to searching for the router it does not detect it and it tells me to reinstall it again. What shall I do?
u can follow the instructions and try and uninstall then reinstall but personally i dont use any packaging software i just use a wired connection and setup the router...anyway here is a youtube video u can view to help setup ur router (http://www.youtube.com/watch?v=EKOZvCCZ7_M&playnext=1&list=PL813062982C965CEE).
Jun 11, 2011 | D-Link DIR-615 Wireless Router
When i install the ethernet software on my laptop and try to connect it does not recognize the printer. The printer is connected to my siemens se567 router and is on when I try the install. What am I...
You need to install as NETWORKED printer. Ensure the printer is Enabled and shared too. Use the links below to set it all up step by step
www.microsoft.com/canada/smallbiz/.../setupwireless.mspx www.microsoft.com/windowsxp/using/.../setup/wireless.mspx
Mar 23, 2010 | Computers & Internet
My moms cable company installed a new modem and left the router disconnected--I reinstalled the software and hooked everything back up and my laptop recognizes the network but seems to be stalled out at...
Hi ,
This is Neo . Thanks for contacting us .
Reset your Netgear and Try it again .
The step to be followed are ,
STEP 1
Reset the Router by pressing the RESET button on the rear till the Test Light blinks.This takes about 10 seconds . Use a pen or paper clip to access it .
Release the button and wait for the Router to Reboot.
STEP 2
Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
STEP 3
If the Router was not cleared after rebooting, unplug the Router's power . Then Press and hold the Reset button.
STEP 4
While the button is held down, reconnect the Router's power . Continue to hold the Reset button for 20 seconds after reconnecting the power . Wait for the router to reboot .
Then Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
Do the setup and try to connect to internet .
The Router will work .
Thanks & Regards
Neo
Thanks for using FixYa.com.
Feb 07, 2010 | NetGear WGT624 Wireless Router
I had a earlier problem with my wireless network adapter in my laptop not fully installing. I bought a driver program and now I should have the most updated driver and the driver is working. my continuing...
To configure the wireless router and the laptop's wireless card, follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 17, 2009 | Linksys WRT160N Wireless Router
I am trying to install a Netgear WGR614v9 router. Disk will not install it, so tried a manual install. Shut down all firewalls, used no passwords or security settings. It keeps throwing me back to the...
The router needs to be configured manually. Follow the steps below.
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing). Or password is admin also.
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing). Or password is admin as well.
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Oct 06, 2009 | NetGear WGR614 Wireless Router
I was wondering if someone could help me setup my
Plug a network cable into the back of your PC and Router. The usually the default router page is http://192.168.1.1
Go to that page in a browser on your PC once you have conectivity. Try using 'admin/admin" to login, if that doesn't work try "Administrator/Password" keep trying a few different combos until you login to the router config page. From there you should have a section to setup the WEP/WPA key. Once you establish the security key you can set it up in your wireless lan card of your laptop.
Sep 25, 2009 | Zoom X6 Adsl Modem/router Rohs...
Forgot password
To ilysurita, cj_mom, top_shutta…
First can I clarify what is meant by a ‘lost password’ …. The original poster here is asking about the password needed to login to the router configuration pages.
If you know the password to login to the router configuration pages, you can still get access to the network key (also known as passphrase, WPA or WEP key, PSK, pre-shared key) – which is the key Windows asks for to connect a new computer to the network. It will be found under a heading like ‘Wireless Security’ or ‘Wireless Settings’ within the router configuration pages. For this model, you can find the router configuration pages by typing www.routerlogin.net (or .com) into a web browser, or http://192.168.0.1
If you don’t know the username/password to login to your router, try using the defaults – for this model, they are admin and password.
However, if the router login username/password has been forgotten, the only way to regain access to the router configuration settings is to reset the router, as described in my posting above. I don’t know of any shortcuts to this one. :(
If you have to resort to this, you might want to wait for whoever set up the router to help with this. This is because resetting the router will remove all your settings – password, network key, ISP connection info – so you will lose your internet connection altogether until it is set up again.
On the other hand, if you’re willing to spend some time and patience, you can have a go yourself.
If you have your original setup CD this may contain a software wizard to walk you through it. If not, you might be able to download a setup wizard from the router manufacturer’s website, along with a quick installation guide (and a manual).
The Netgear site also has very clear troubleshooting and support pages which will help with setup, even if you don’t have any setup software:
http://kbserver.netgear.com/products/wgr614v9.asp
Make sure you use a wired connection. Also, print off all the information you need before you begin, as you will not be able to access the internet while you are setting up the router.
Good luck whatever you decide to do
Dec 21, 2008 | NetGear WGR614 Wireless Router
NetGear RangeMax WPN824 Router Logo
95 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
