Question about Kenmore 64522 Top Freezer Refrigerator
Kenmore fridge not getting cold
I have an older kenmore fridge,it has bee great till now. it has stopped getting cold altogether.the fan on the side is running,but i noticed heat coming from the bottom,the motor and some of the lines are extremly hot,is this fridge done?
  • James Bradburn
    James Bradburn May 11, 2010
    Eather it needs to be recharged with freon, or the compressor is shot. You can recharge it and try that if you like but it will require a part to do that.
  • 410 Answers
First thing to heck would be the condenser fan motor which is located int the compressor compartment pull the refrig away form the wall remove cardboard cover and inspect the fan motor that you will see. check for obstruction or if the fan motor is seized. if this motor fails it will cause the compressor to run extremely hot then shut off on internal motor protector. if you determine the motor is bad you can place a house fan behind unit blowing on compressor area to keep unit working until you get it repaired.
Thanks Peyton
Posted on Feb 17, 2009
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Samsung rs 2556 SH side-by-side fridge is making a loud whirring noise, but when I open the fridge the noise comes to a sputtering stop. It starts again a few seconds after being closed. Noise sounds...
there is a evaporator defrosting problem; ice building-up. the evap fan is mounted right on top of the evap coil. this will get progressively worse; and, the fan will get completely jammed with ice; and stop altogether. your fridge will get warm and the freezer will not cool properly. you should get it looked at asap..
May 18, 2010 | Samsung RS2630WW Side by Side Refrigerator
Fan keeps stopping
Don't worry about that. There is nothing wrong with your refrigerator. Every company is asked to follow some norms of power saving and you just witnessed that. The fridge is cold enough. If you are doubtful about that, Just check out with a thermometer.
Apr 21, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
Sep 03, 2009 | Refrigerators
The refrigerator part stop getting cold, but freezer part is still working, what do i need to do
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge is not cold and freezer is not frozen
check to make sure the fan that blows cold air from the coils of freezer is working. If its not that could cause the freezer to be cool also.
Nov 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 64522 Top Freezer Refrigerator Logo
273 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
