Question about Whirlpool MH3184XP Microwave Oven
Microwave (suction) fan not working
When turned on, the fan doesn't seem to be suctioning the steam/smoke form the stove top when cooking (and it trips my home smoke detector). I can hear the exhaust fan blowing and can feel the air coming out at the top. Does this microwave have a separate suction fan? If so, where is it located and how can I fix/replace it? If none, what could be the cause(s) of it not sucking/suctioning the smoke?
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Fan on over the range microwave
This may be caused by a weak fan, improper installation, clogged filters, blocked air ducts, or a blocked outside vent.
Assuming yours is a Whirlpool, you can download Whirlpool owner's manuals and installation instructions here.
This will help you check the mounting and setup, as well as helping you check the filters to see where the problem lies.
Please write back with your brand and model number if you yours is not Whirlpool.
Posted on Jan 02, 2009
No suction on my microwave
Over-the-range microwaves have lights and fans in them mostly for show. They protect the microwave from heat rising from the stove and provide a light to illuminate the stove top. The fan assembly is far too small to generate any real pull or draft and if it did, it would only blow it back in your face since these models do not exhaust to the outside; they only exhaust out the front of the microwave. A few models have a "filter screen" that is supposedly there to catch grease and contaminates but really it only serves to further weaken the draft as it provides a resistance to air flow.
Oct 14, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
For the Jenn-Air Model JMV8208AA The microwave was dealer installed and is room vented. The vent does not pull vapors from the cook top of the oven. Regardless of the venting level used, the pull...
Sorry to read about your problem, I hope this helps you out.
Well first of all I would take a piece of paper or newspaper, and put it up by the vents, the paper should be sucked on by the vent.. If it does that you have suction. if it does not hold the paper, you should get a warranty repair, i am assuming this new.
If the unit is install to far above the stove you may have a issue.
But long story short, the room vented units, do not really pull much smoke, they pull better on outside venting. you are just putting smoke/steam back into the room, just a little cleaner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Jenn-Air JMV8208AAS Microwave Oven
Microwave has no vent suction
check the filter(s) under the microwave. The normally fill with cooking grease and clog producing less suction. Remove the vent filter(s) and turn on microwave and you'll see a drastic difference. The are replaceable at any home center like Home Depot, Lowes, etc. and are very inexpensive. I hope this helps and good luck!
Dec 03, 2009 | Microwave Ovens
My fan works on my microwave by it does not draw suction
Actually, the fan in the microwave is only there to cool down the magnetron which cooks the food. It gets very hot over a period of time and the maintains constant temperature across it. Suggest you use an extractor to remove fumes.
Sep 27, 2009 | GE Microwave Ovens
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
Suction fan on GE over-the-range microwave
If the blade is not big enough, the motor not powerful enough, or the vent size is wrong then it will not work properly, On thing you can do is check the vent cap and make sure that it has not falling down onto the vent pipe and blocking air movement.
Feb 11, 2009 | Microwave Ovens
Fan on over the range microwave does not have enough suction to **** the steam from stove through the microwave. Does the blower get turned a certain way for this to work? Is there a .pdf operational...
Jan 02, 2009 | Whirlpool MH1170XS Microwave Oven
Exaust fan has weak suction on maytage mmv4205baw
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Dec 10, 2008 | Maytag MMV4205 Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Whirlpool MH3184XP Microwave Oven Logo
394 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
