Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
PC SOUND DEVICES
Hi Good Evening,
Can someone help me fix these problems:
1. My Computer don't have any Sound Card
2. Window Media don't play any movies DVD/CD
Can someone please assist in giving programs to install?
Thanks in advance
I can`t ear a sound in my computer
Posted on Feb 24, 2009
I have this message apprear on my laptop when i try and play sound "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device...
try playing the sound file with other media players, if still not playing reinstall ur audio driver either by dowloading the driver from internet or by installing it from ur driver cd.
if ur audio device driver is integrated or plug n play device then,
step 1:open control panel
step 2:open 'sound speech and audio devices'
step 3: in the property menu of audio devices select drivers from the tab
step 4:select uninstall driver.
step 5: restart ur computer and the audio device will be reinstalled.
if it is the problem with ur windows media player, then step 1:select option/preferences from the menu.
step 2:select devices from the tab.
step 3:test all the devices by selecting each one at a time to play ur sound file.
Jun 19, 2011 | Acer Computers & Internet
It cannot playback audio sound. it tells me that "Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your...
Most likely your soundcard driver is not correctly install you need to reinstall it.
Verify first if there is sound card driver installed.
1. Click on Start then select Run
2. On the Run box type dxdiag then click on OK
3. Just click on Yes on DirectX Diagnostic Tool prompt
4. On DirectX Diagnostic Tool Window click on Sound tab
Note: Please take note of the Device name
2. On the Run box type devmgmt.msc then click on OK
3. In the Device Manager expanc the Sound, game controller
4. uninstall the Sound card named
5. In the Device Manager, righ click on the computer then select on Scan for hardware changes.
Note: If the sound device did not get installed manually download the sound card driver from its manufacturer's website.
May 25, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not...
hi, here are some solution plz try them all..
1. Have you tried updating the sound card drivers to their latest version?
Don't just check Windows Update, but the card manufacturer's website as
well.
2. Here is a simple quick fix!!!!!!
Open the Media Player
At the top, Click on "Tools"
Select "Options"
Click on the "Devices" tab
In the list of devices, double-click on "Speakers"
Under 'audio device to use' it probably lists your sound card ...THIS IS WRONG!!! !using the selector button on the right side of the window, change this
setting to:
"Default Directsound Device" (Note that "Directsound" will show as one
word).
This problem happens because MS never should have allowed this setting
to be changed ... it's senseless.
3. Click Start, then Run. Type dxdiag, then click OK. Choose the sound tab. You should see your device and driver there and you can even test the sound. If there is no device or driver, just install it and check it with dxdiag again.
Hope that helps,
Regards,
Pankaj
Oct 11, 2010 | Computers & Internet
Sound is nt coming from speakers?
Do you have two sound cards in your computer now or have you removed or disabled the old sond card?
FYI, looks like in the media player you havent selected the right sound output.
Try this,
1. In Windows Media Payer, Menu bar-> Tools -> Plug-ins -> Options.
2. Go to Device tab and click on Speakers ad the click Proprties button below.
3. Click Advanced
4. Select your new hadrware.(Creative Aspire 5.1)
5. Click Set as default.
6. Click OK, OK OK...
Then restart Windos media player and try again.
Another thought, make sure you have pluged the jacks right and you speakers are working right.
Good Luck!!!
Feb 20, 2009 | Creative Labs Sound Blaster Live! 5.1...
Sound device
If your sound device is removable, like PCI Card, try to remove the PCI Card and clean the connector with dry brush, then place it firmly back again.
If your sound device built-in on your motherboard, please re-install the Device driver provided by the Motherbard Driver CD.
-mrsolution
Jun 11, 2008 | Computers & Internet
Sound device problem
hi abdi,
the problem is that your sound driver is not installed. You might have got a driver cd when you purchased your PC. Installed the required sound driver and you are done. if you dont know what driver you need you can try sound max or realtek ac97 or conexant audio driver...
hope it helps
regards
bozy
Jan 20, 2008 | Logitech X-530 Computer Speakers
My speakers have stopped working.
Ok, I may have the solution. After I posted here I went back to trying to fix it myself and I did, well, mine anyways. I back to the control panel and went to Hardware/Sounds, clicked on the manage my audio devices again, and then where it said "no audio devices installed", nothing there, I right clicked my mouse and it brought up a little box that said: Show disconnected devices and Show disabled devices, make sure both of these are checked...that was my problem why i kept showing nothing. Then hopefully your spears icon shoud reappear like mine, and you can then click on it, then properties, and ENABLE it...hope this helps, let me know :)
Nov 11, 2007 | Audio Players & Recorders
MEDIA CENTER
Hi! White Dove,
First things , first, check the cables in back of your computer, and see if cables are in the right order, green, pink or orange, and blue, and put the cable speaker in the green one, also check if you have the right drivers for your sound card, and is not place in mute on the task bar.
hope I can help!
Carl
Nov 05, 2007 | Computers & Internet
NO SOUND DEVICE
u need to check the sound driver on>try this
right click-->my computer-->and properties-->hard ware-->and device manager-->and audio devices-->right click-->properties-->and click-repair-->or trouble shoot>and rebooot teh pc>and try
once u went to the device manager on teh audio device u can see red X mark or some thing which means the driver is not loaded try this rate me solved>
Oct 20, 2007 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
