Question about Acer Computers & Internet
Lost power plug for external
I need to know where to get the ac adaptor for my ACOM DATA external hard drive I believe its a 4 pin
  • 10,865 Answers
Go to radio shack with the adapter and they will assist u.
Posted on Feb 17, 2009
Lost power cord
I believe that you would be ok. Voltage has to be "Spot on." Amperage, however, needs to "meet or exceed." Think of Voltage as pushing something into something. Think of Amperage as pulling something out of something. It won't draw more amps than it needs, even if they are available. Allow me to thank you for including the powerpayless website as until your post I didn't know what voltage I was looking for. Exactly the same thing happened to me with my SimpleTech 1TB. Perhaps we both solved eachother's problems. PS: I'm going to check with Radio Shack for a 12v adaptor with at least 3.5 Amp capacity. They might can beat the $30.00 which is what the above mentioned place gets including shipping.
May 16, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a good power supply, but the unit will not power on using AC or USB power source. Can I move the hard drive to another unit to recover my data?
If the hard drive has a SATA fitting and Power SATA fitting like a normal hard drive ( or the 4 pin molex and an 40 pin ide fitting) yes you should be able to
Mar 30, 2011 | Vantec 1 Bay NexStar 3 USB 2.0 External...
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
http://hddlist.com/maxtor/all/maxtor_basics_portable
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Not working
The only help I can offer is to suggest trying another power adapter first. I've serviced several Maxtor external drives that lit up but wouldn't spin (just clicked), and the trouble turned out to be the power adapter was just too weak. If the adapter is okay, the trouble might be on the interface board inside the case. You would need to remove the drive from its enclosure and connect it directly to a PC power supply to check it out. If the drive itself is in fact faulty, your only option is to contact a data retrieval company to see if they can recover the data from your drive. Be warned: this is an expensive operation.
May 26, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Computers & Internet Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
