Legend LCD tv power issue
When i turn my tv on, it can take up to 10 mins to get a picture on, it started with the sound coming in a bit after ther channel changed. Have Legend EDTV powers up and green light just blinks then goes on steady.. All Manual Controls wont work and i get no Pictuture it is model number L1527.
  • rguinan Mar 10, 2009
    I have same issue, television won't turn on
The problem is inside th vga hdmi board ,i have repaired 2 of these units the 37 inch version and found a bad 100 mf 10 v capacitor . little bit of soldering/de soldering skill is needed . cost of cap 0 dollars got it from old radio. ernie
Posted on Nov 18, 2010
  • SushiX Feb 07, 2012
    I just repaired my tv, locate and replace all 3 of them (100uF-10V) capacitors. On the VGA-HDMI board, they are SMC's (surface mountable components)
    I used 100uF-16V for the replacement parts, got from an old VCR.
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
Picture on tv goes black after 10 mins, the sound still stays on but no pic. then if left turned off for while picture will turn back on but on;ly for 10 mins again
What you described here is a issue with the LCD back light or one of the inverter boards going out on you. These boards can be found www.partstore.com or www.shopjimmy.com
From what you described this is basically what I come up with, if you update me with a serial number/ model number we could get you the part number and price.
Thanks
Rulds2008
Apr 13, 2011 | LG RU-27LZ50C 27 in. HD-Ready LCD...
Turn on picture and sound are great. for about 60 seconds. then the picture disappear but sound is great. turn power off wait a little bit ( try differ times. from 15 seconds to 10 minutes) Turn back...
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead.That why,the tv have picture only flashes like a min. than,died and have sound left only.The LCD long inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 16, 2010 | RCA L32HD32D 32 in. LCD HDTV
My Sony KDF-E42A10 turns on and then after a min the picture and sound will go away and the light "Power/Standby" will flash green. after a little bit the TV sound and video will come back on for a...
It is symptom of weak lamp that reaches at end of its working life, replace lamp in tv to fix the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 31, 2010 | Sony KDF-E42A10 42 in. LCD Television
Have a 42'' lcd legend and have similar problems. It started taking about 5 minutes to turn on, then longer, then longer, until finally it didn't come on at all. The power light goes from red to blue, but...
The problem is inside the vga hdmi board ,i have repaired 2 of these units the 37 inch version and found a bad 100 microf 10 v capacitor . a little bit of soldering/de soldering skill is needed . cost of cap 0 dollars got it from old radio.but it takes along time to repair-you have to remove the back cover and note lot of screws .ernie
Jan 12, 2010 | Televison & Video
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
Everything looks great then the picture goes off, the green light blinks on and off but no picture comes back..intermittandt, but will occur every 10 to 15 mins or so, have to unplug the set and then...
You have the television on sleep mode. You'll have to disengage the sleep function! Most tv have this option so that you can go ahead and snooze for a while and the tv will turn itself off!
Dec 07, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
My ASTAR 32 inch has no picture or sound for 10 mins on start up. Happens if tv has been turned off for a couple of hours. I get blue screen then snow screen and eventually picture will come up but may be...
You have an AC resistance problem on the interface board. Passive components such as silver mica and electrolytic capacitors are not charging and discharging properly. This causes a delay or disruption in the start-up process. Byte signals are weak and intermittent due to other thermal components failing such as 'diodes, smd mosfets,...etc...''' Believe it or not this happens from manufacturers using 'inferior-grade' circuit components that fail under considerable load conditions. By replacing a few parts with better quality parts will solve this issue for you. To replace these parts requires removing the back cover and using some test equipment. If you can get someone who is technically proficient I can e-mail them instructions on how to fix this problem on the circuit board.
Let me know if you want to follow up on this...
Dec 07, 2009 | Astar LTV-3201 32 in. LCD Television
Why does it take 10 minutes for my LCD Legend tv
Sounds like you have a faulty capacitor on your invertor..Gently press on the screen when there is no picture.is there light on the screen? If so, there is backlight but no video..hence a mainboard or power supply problem..If there is no backlight then the problem is the invertors or the power supply not supplying 24volts. The invertor is located on left or right hand side of screen..Check that all connections are secured and not loose.Check that the power supply capacitor tops on the power supply do not have bulging tops..If not, and voltage is reaching the invertor, then remove the invertor and check for bad solder joints and leaking capacitors.
Oct 17, 2009 | Televison & Video
It's the power supply gone bad, just had the same problem. The repair guy charged $195.
Apr 19, 2008 | Televison & Video
Televison & Video Logo
493 people viewed this question
Top Televison & Video Experts
