Question about HP PSC 2210 All-In-One InkJet Printer
I need connect the laptop
Dell Laptop
  • 2,976 Answers
Get the proper cord and plug it in. It can go into a serial port or a USB port on the laptop. You'll need a power supply also.
Posted on Feb 17, 2009
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Using a Dell Inspiron no apparent power to laptop with our without a adapter. New universal laptop charger...still light on charger goes off as soon as connected into laptop power port.
sounds like the laptop has a motherboard fault, dell laptops need to be run from dell chargers only and at correct voltage and correct amps output. the information is normally provided on lable on the base of the laptop, universal chargers do not normally work on dell laptops, would suggest you try and use original dell charger .
Aug 07, 2013 | Computers & Internet
Dell 510 laptop to panasonic tv connection but no sound
You need to connect an audio cable from the headphone socket on the laptop to the audio input on the TV.
Apr 20, 2013 | Dell Inspiron Computers & Internet
No signal when I hook my Dell XPS laptop to my Element HDTV
turn off tv and laptop. connect the hdmi cable to your tv and laptop turn tv on then log onto your laptop Both devices need to be off when connecting the hdmi cable
Apr 13, 2013 | Dell XPS Computers & Internet
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
How do i get my dell inspiron E1705 to connect wirelessly?
First of all make sure the Wifi is turned on your laptop.
You need to press Fn+F2 at the same time to turn the wireless on. Once its on you need to connect to the wifi network in range and you are good to go.
Oct 11, 2012 | Dell Inspiron 1525 Laptop
Dell laptop connected to yamaha reciever via hdmi no picture or sound?
This has to do with your video driver on your laptop that needs updating.
go to Control Panel\All Control Panel Items\Windows Update
download any updates from here.shutdown laptop, check the cable connection from laptop to tv then restart.
If still no luck try another hdmi cable
Nov 25, 2011 | Dell Studio 1537 Laptop
Dell Studio Laptop 7HP06H1 We cannot get the
Hello, Lyn.
On the left side of your laptop, you'll find a wireless on/off switch. See if that switch was turned off.
Hopefully, that will help.
P.S. I didn't grow up in the computer age, either.
Jun 10, 2010 | Dell Studio 1537 Laptop
Hi trying to connect my dell laptop to pc
to connect a laptop to you PC you will need a broadband router(with min of 2 LAN slots) and connect both using the LAN network cables thru the router.
Then on both PC and laptop you need to create the local area network.
Start/Control Panel/Network Setup Wiz/next/next/No let me chose another...../next/other/2nd option This Computer connects...../Computer name...Give a name/next/MSHOME/next/1st option Turn On file and print..../next/Yes/Next/wait for a few min..../Last option...Just Finished the ....../Next/Re-start/
Do this on both PC and laptop
Now open My Computer icon/Clikc the up arrow button near the top the menu bar/
this will show you the My Network icon/click it and view all computers on the network
You need to do the above process on both the PC and laptop
once you can view the PC's shared folder in you laptop and Laptop's shared folder in you PC you are DONE.
just copy any files from your PC/Laptop to the shared folders on you laptop/PC and exchange files on both.
all the best
Dec 07, 2009 | Dell Inspiron 1501 Notebook
HP PSC 2210 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
