Question about D-Link DIR-625 (790069292637) Wireless Router
Getting limited access on my laptop
I am setting up my laptop and I am getting limited access when I try to get on the internet. I have the D-Link Router. It works great with our PC's but is not working with the laptop. Does anyone else have this problem?
  • 49 Answers
Try to re-configure your router for the wireless connection and disable WI-FI protected setup located at advanced.
Posted on Mar 26, 2009
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
How do you change limited internet access to full access
Limited access usually means you have full access to your network through your hotspot, but the hotspot is not connected to the internet or it cannot get a signal.
Sep 25, 2012 | Dell Inspiron 1525 Laptop
How do I use my laptop as an internet source for my wireless router?
You Internet access is through the cable or DSL modem.
Connect your wireless router to the cable or DSL modem and then configure the wireless router with the wireless encryption settings. Then configure the wireless cards in the laptops with the router's encryption settings etc. This will then allow the laptops to connect wirelesslt to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 05, 2012 | Linksys WRT Computers & Internet
The internet works just fine on the laptop, but when I try to get on with my laptop. Apparently I am connected to the network, but I can't get internet access.
I believe you have limited connectivity, just right click on the network connections icon on your system tray and the select repair so that you will get a new ip address.
Hope this helps
Thanks
Dennis
Nov 03, 2011 | D-Link DIR-615 Wireless Router
I have a compaq laptop with zoom wireless router/modem. The router is working fine but something is blocking my access to the internet. It states either local or limited access. My two other laptops are...
Did you try to install the drives first? try that. see if the laptop gets an IP from the router (by default 192.168.x.x).
I would also try to plug the laptop directly to the router and see if it works (with network cable plugged between the two)
Nov 10, 2009 | Computers & Internet
I am trying to connect a new laptop to my home network. The wireless connection indicates that it is connected to the internet, but i canno get to the internet. I have statically assigned an IP like...
Internet explorer... Under the address bar you should see "file, view edit,favorites, tools and help" click on tools, internet options and go to the connections tab. make sure you have nothing in the white box then click on LAN settings. I bet you have "proxy settings" checked. None of the boxes should be checked.
Oct 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Limited or no connectivity
It is dhcp server issue.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to advanced and enable dhcp .
Then save settings and then restart .
Also you can set ip addrese manualy but make sure it is in range with router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | NetGear WGR614 Wireless Router
I have DI 524 d-link. Internet works on desktop and one laptop. Just got a new laptop and everytime I try to connect on the network of 1st. laptop, it says connected with limited access. unable to have...
Make sure that every setting in the new laptop matches the settings in the router. If one setting is off, you will not get a connection. It is also possible that the router is set to only allow specific computers to connect to it. If that is the case you will have to add the new laptop to the allowed connections in the wireless settings of the router.
Aug 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Limited access on internet
Try this link. It contains the common causes of limited connection and some solutions that you can try:
http://www.fixya.com/support/t1662136-limited_access_internet
Feb 12, 2009 | ASUS F3E-AP183E T7250/2.0/160/1G/15/VBS PC...
D-Link DIR-625 (790069292637) Wireless Router Logo
1,685 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
