Question about KitchenAid KEBC107 Electric Single Oven
Kitchenaid Superba Wall Oven KEBC107KBL No power to display
I don't know what happend.. One day I looked at my oven and the display is completely dark. Buttons don't work, circuit in the breakbox wasn't tripped. I tested with meter and it has 208 coming into the oven. I have unplugged all the wires to the display and re-plugged with no luck. All the wires behind the display appear to be corrosion free and still tight. I am affriad I will have to replace the display but not sure what to do without having a repairman come out. Any help would be greatly appreciated.
Thanks
Tony
  • 1 more comment
  • joe7629 Mar 01, 2009
    Same problem with my KEBS107BL (4). several brown-outs with our electrical service left a display of Sab. Turned off breaker for several hours, "control lock" displayed. Followed directions to disengage control lock by pressing control button # 3. display went balck, now have F2-E3 displayed in clock display.
  • tony_messers Apr 25, 2009
    Well ****. Replaced the control board and display, still no luck. Anyone have any ideas what I could test next? I checked the oven shutdown fuse and it seems to be good...
  • tony_messers May 14, 2009
    Finally I fixed it. So I replace the controller board and the electric panel. Still no luck. So I started testing with my multimeter and found that the 25V transformer for the panel power wasn't working. It was being fed 120 but returning 0. So pulled out the transformer and looked at the connections. Turned out that the wire coming off of the transformer where the male end of the connector hooks up to had worked loose from the sauder. I re-suadered the wire back on and bam we're back to baking.
    On a funnier note, the replacement part for the panel, non-refundable, that Kitchen Aid fed-ex'd me some of the buttons didn't work so I put the old panel back on and life is good.
SOURCE: kitchenaid double oven shut down!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Posted on Oct 05, 2007
SOURCE: kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Posted on Nov 29, 2008
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
SOURCE: Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Posted on Jul 11, 2009
Oven keypad is completely black but inside oven lights work. does keypad have a separate fuse?
Yes. Many of these have a display thermal fuse that is part of the wiring harness that connects to the board... it should have continuity. WP4451042. Almost all models have what is called the "oven shut-down thermal fuse" which is on the back of the machine ( you have to pull it out of the wall and remove the back panel) and looks like this KitchenAid Range Stove Oven Thermal Fuse WP9759242
Dec 06, 2014 | KitchenAid KEBC208 Electric Double Oven
I have a kitchenaid Superba convection oven. I be something else?
it sounds exactly like an ignitor, if u want the original ka part u will pay more,, you could use a 12400035 ignitor, or a sgr403, depends if its round or flat, go to repairclinic.com and enter those part numbers in to see pictures of those, or look up a ka ignitor and compare prices. hope this helps let me know whut u think
Feb 12, 2010 | KitchenAid Ovens
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
My kitchenaid superba oven door..
Contact the landlord and have him repair or replace the oven.
Aug 24, 2017 | KitchenAid Ovens
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
KitchenAid KEBC107 Electric Single Oven Logo
1,603 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
