Question about JVC KD-PDR30 CD Player
No memory ive crimped the memory wire twice now and every time i turn the car on tha deck resets its memory... what could be the issue?
  • I3oston Feb 17, 2009
    yeah i just checked them and i connected both wires correctly... the yellow 12v wires look a lil different tho on of them is gold while the other is silver would that matter or no?
  • 148 Answers
Check to make sure you don't have the batt+ wire and switched 12v wire mixed up. batt+ is usually yellow or orange while the switched 12v wire is usually red, consult the manual or look on the unit itself. there should be a wire color description there. batt+ is what you want 12v running to all the time to keep the settings. switched 12v is the one that turns the unit on when the key is turned on. the unit will still operate if the 2 are backwards but like you said it will clear the memory every time you shut it off because your cutting power to the batt+ wire thus resetting the unit.
Posted on Feb 17, 2009
  • Nicholas Csorba Jr. Feb 17, 2009
    i double checked and the constant (memory) wire is yellow aka. batt+ and the switched (accessory) wire is red. aka 12v switched, yellow to always on 12v source and red to accessory switched 12 v.
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
Car deck memory issue
Is the fuse blown on the memory wire from the decks wiring harness. Also, makes sure memory wire and accessory wire are not flip flop.
May 24, 2012 | JVC Car Audio & Video
When i preset my radio stations 1-6 while the power is still to the system memory of stations will stay but when the car stereo power is turn off for any amount of time and sterio is turn back on all...
Make sure the yellow wire is connected to a source that still has voltage when the key is turned off. The yellow wire controls the memory of the deck.
Jul 24, 2011 | Alpine CDA-9851 CD Player
Bmw 318i se auto clock reset problem?
a little more information would be nice but im going to make a guess
you installed a new deck in the car, now every time you turn the car off the clock resets?
if thats correct.. the deck will have 2 power inputs, one that turns the radio off when it does not have a power signal, the other that should have a constant voltage to maintain the stereo memory, now if I'm correct you have either the 2 wired opposite to how they should be or both wired to something like the ignition wire, and it is acting like the battery has been removed every time you turn off the car, which means you need to check your stereo wiring.
if this is incorrect please leave some more info telling everyone when the clock is automatically reseting.
Aug 06, 2010 | Car Audio & Video
Deck turns off when i hit a bump in my car
A couple things...but the deck must come out to check. (assuming this is a 12v N.American car) If you cannot remove or you dont know how - take it to a car stero shop. Electrical fires are nasty!
  1. Make sure there are no open wires and connections are tight and taped (badly crimped connectors will hide loose connections)
  2. Make sure the deck is supported in the back-it should not wiggle around.
  3. There should be a wire firmly connected to the chassis of the car and the back chassis of the deck - Please do not drill into the deck - use an existing bolt !
Nov 07, 2009 | Pioneer DEH-1100 CD Player
My memory wont work after 5 minutes or truck shut off but will after a minute or less
Are you positive that the yellow (memory wire) from the Panasonic (use a test lamp or meter) is continuing to get power after you turn off the truck and wait 5 minutes? And the Black ground is proper ... If so then it will likely cost more to repair the deck than replace it. Or you could wire the red wire to the same place the yellow wire is wired to ... then just remember to shut it off when you leave the car (or suffer a dead battery 12 hours later) ... and it won't cost more that the cost of a couple crimp connectors to do that ... the frugal way.
May 13, 2009 | Panasonic CQ-C1300U CD Player
Constant Power wire draining battery HELP!
Okay, I think I have it. The red and yellow wire into the deck need to be connected to two different power sources.
The red wire should only be hot when the accessory switch is on. The yellow wire is for constant power to maintain memory in the deck.
Connect the red wire to a source which is only hot when the ignition switch is in accessory position -- that should solve the problem.
May 06, 2009 | 1984 Lincoln Town Car
Kenwood kcd-mp335 cd player
You might best bet would be on the memory wire not being shot solid 12 volts. There are 2 wires meant for 12 volts the red one which has 12 volts on it when the car is turned on only. And the yellow wire which should be at 12 volts all the time. If you have power at the Yellow wire at all times then you might have a deeper issue. I hope this will fix it.
-Andrew Hawkins
Mar 14, 2008 | Kenwood KDC-MP335 CD Player
JVC KD-PDR30 CD Player Logo
249 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
