Bought a camper with carrier ac with remote, cant seem to get it running? no manual..anyone help me to get started, I checked fuses..
SOURCE: i dont know what kind of roof top ac is on my
Most of those types of units are not belt driven. that are direct drive, and some even have just one double-shaft motor which drives both the evaporator and condenser fans
SOURCE: Carrier Desert Master AC trips the fuse
1- check the fuse must support the current of the unit not less than (rla of the unit)
2- check freon pressure may below or toohigh causes compressor winding over heating
3- check fan motor winding
Testimonial: "Thanks so much, great and fast help..."
SOURCE: was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
SOURCE: i just bought a fema trailer and its missing the
yes, but when you take the cover off you will discover the name plate with the proper info to replace the remote, also your fema preparer might have placed the remote there as well. thank you and good luck
