Question about AudioBahn DUB240 4in DUB Series ( DUB MAG AUDIO ) Car Speaker
  • Stephen Davids May 11, 2010
    your gunna have to be a little more specific. do you have an amp? if so what watt? find out how much each speaker's max wattage is and then add it up to find out the size amp. your gunna want to subtract a few hundred and get a little bit smaller amp than your max wattage so you have a safe zone and don't blow anything
  • blueextc3221
    blueextc3221 May 11, 2010
    single or dual voicecoil?
    How many ohms is each Voicecoil?
    What amplifier are you using?
  • 77 Answers
There are many ways to wire in subwoofers check the impeadance on the sub and the stability of amp by referring to the users manuals. once you know the ohms you can check for wiring or give more information on your question and i will do my best to resolve it.
Posted on Feb 18, 2009
Also I have two harnesses that plug into factory radio one has 12 one has 4 do I need the 4 wires I just want to radio again that's all
Generally, the 4 wire plug is for power only.
The 12 wire is for speakers only.
Most often, plugging in the 4 wire may get your radio to "light up", but you would have no sound.
By the same token, the 12 wires plug only power the speakers, so hooking it up will not power the radio to work.
God bless your efforts.
Apr 12, 2016 | Cars & Trucks
How do I replace the wire that's connected to the sub?
Just go to an electronics store or Walmart and buy some wire.
Sep 13, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
Below is a listing of the radio wires and what they control.
1995 Chevrolet Camaro car radio wiring schematic
Car Radio Battery Constant 12 volt Wire: Orange
Car Radio Accessory Switched 12 volt Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire: Tan
Left Front Speaker Negative Wire: Gray
Right Front Speaker Positive Wire: Light Green
Right Front Speaker Negative Wire: Dark Green
Car Audio Rear Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire: Yellow
Left Rear Speaker Negative Wire: Brown
Right Rear Speaker Positive Wire: Dark Blue
Right Rear Speaker Negative Wire: Light Blue
Jul 08, 2014 | 1995 Chevrolet Camaro
I just purchased 2 12"
bigger is always better, use the 12 if you have it. higher gauge = thinner / not better.
Mar 08, 2011 | Cerwin Vega E-312 Speaker
Keep blowing fuse for radio what is colr of constant wire
The constant 12 volt wire is yellow. The accessory ( switched 12 volt wire) is red. The blue (power antenna) and blue/white (remote amp turn on) are also switched 12 volt wires. Make sure that they are not being grounded.
Oct 10, 2010 | Kenwood Car Audio & Video
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
We are trying to install a pionere radio and without the power antena/system control wire hocked up the speakers have no sound when you hook it to 12 volts the tweeters click what should i do
The antenna wire, witch should be yellow. is not supposed to be hooked up to 12 volts. It is only meant to be used as an on censer . If that wire is the reason your speakers are not working then the stereo is defective. That wire should have 12 volts coming out of it when the stereo is on. And hooking it to 12 volts could have damaged your stereo. I would look at the wire diagram again before doing anything else.
So anyway if you are not using the power antenna wire cap it off and leave it alone. you do not need it. Check all of your connections again and follow the wire diagram.
Good luck.
Aug 08, 2009 | 2001 Dodge Dakota
Panasonic CQ-DP620AEUC pinout (car radio/CD player) bought used from my brother. He didn't have the wiring pinout diagram anymore. Which wire is the "memory" connection to 12 VDC?
Yellow wire is always the memory or back up, which is always 12 volts even with key off. Red is for ignition, 12 volts only when key is on. Black is ground. Speakers are color coded in pairs, the grey and white pairs are the fronts and the green and purple pairs are the rear speakers. Each speaker wire with a black stripe is the negative speaker lead and the solid color is the positive.
If you need more help just let me know and a FixYa! rating would be appreciated.
Jul 13, 2008 | Car Audio & Video
Car Audio & Video Logo
57 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Nicholas Csorba Jr.
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
