Question about Mitsubishi VS-70707 70" Rear Projection Television
Mitsubishi VS70707 Has developed subtle lines in picture
My son was watching Tom and Jerry one day when I noticed the TV was displaying really vague horizontal lines in the picture. The lines went away and I figured they were from the cartoon, but they soon came back. They create a soft flicker like the tv isn't refreshing fast enough. Most people don't notice them unless you point them out. If you can't see them from across the room, but you can when you within 10 ft of the screen. They used to only appear on bright backgrounds, especially white, but now show thru at all times. I cleaned some of the dust off of the chassis, made sure all of the boards and cables were seated properly and tapped on the heat sink to knock loose all of the dust. After this, the lines were almost gone, but came back after a couple of hours. The tv is rated for 850 lines of resolution, but it appears as if I am only getting half of that. It doesn't matter what input I use or form of media, it is present on DVDs, games, cable. I love this TV and would like to hold of on a replacement, but just can't figure out what is causing my line problem. Any ideas would be greatly appreciated! Thanks!
  • mechelecman Feb 17, 2009
    Great idea, but it only made the picture blurry. Here is an image so you can see the lines. You may have to zoom in to see them.
    Sorry, the picture's not posting. I can e-mail it too you if you would like to see it.
    Thanks!
  • 43 Answers
If they are faint white lines, they are called re-trace lines. They are caused when the current to the CRTs is too high. One way to check is to turn the brightness down. They should go away, but if the picture is too dark, you will need to turn down the "screen" control. This will take some handy work. If you are handy enough, take the grill off the front. Inside you will see a little black box, about 5 inches wide. there are 6 knobs on it, 2 for each color. One row is for focus (each) the other for screen (brightness). It is written on the part. The trick is to turn each of them down equally or risk having a slight tint of color. Really not hard at all, but requires the TV to be on to see. You shouldn't need to turn it but a fraction. Good luck.
Posted on Feb 17, 2009
My Mitsubishi tv vs70707 convergence problems. I just replaced my 2 STK convergence chips, and double check my soldering. Still have 3d pictures and can't find pico fuses. Glass fuses are ok.
Need a better picture, but usually fuses are listed as F(number) and would be on the power input to the STK chips. The resistors should be checked as well.
Feb 28, 2015 | Mitsubishi Televison & Video
Picture Problem
Model is Mitsubishi WD-62725?
The other question is does it do it on tuner and REAR inputs?
Mar 23, 2012 | Mitsubishi WD-62725 62" Rear Projection...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
Jun 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
We have a Samsung pch521r that was given to my son, we can turn it on but we are not able to get a picture. We cannot even set any settings on the tv. Please Help! My son was so excited to get this tv!
I am sure that it was given because the former owner knew there was a fault!
Very commonly the power supply or high voltage sections fail in these. The tubes in projection sets also go weak and cause failure.
If the set is more than 5 years old it will not be worth investing any money in to it. TV's are not very expensive these days. You should buy your son a nice TV set that he can enjoy. The LCD and Plasma displays will far outperform any of these older projections sets.
Jerry G.
Apr 26, 2009 | Samsung PCH521R 52" Rear Projection...
Where do I find a service manual for the VS70707 model?
Go to www.sears.com dept parts....have make and model ready!
Dec 11, 2008 | Mitsubishi VS-70707 70" Rear Projection...
RCR412S Remote Control with RCA TV
If you haven't lassoed your son yet, you might find some answers here:
RCA Remote Codes
Nov 29, 2008 | RCA 3-Device Universal Remote with...
Picture issues
your green tube is trying to go out
Oct 21, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi VS-70707 70" Rear Projection Television Logo
299 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
