When I cross solenoid it turns over but nothing when I press the starter button@
SOURCE: 2005 Honda Shadow Sabre starter doesn't always
Check the connections on the starter solenoid and on the starter. Then I would check the starter button.
SOURCE: wont start! bike wont start with starter button
sounds like a soleniod problem,
If you tap the solenoid while pressing the button it may start, but will confirm the solenoid is sticking
SOURCE: 1988 honda shadow vt1100, wont
Hi, sounds like you are getting insuficiant power getting to the starter, assuming you have checked the engine turns over freely and is not seized, the switch circuit you have proved is working (as the clicking noise at the solenoide indicates this) as the solenoide switches the battery power to the starter motor, i ask myself if either the battery is suffiantly charged, or the leads from the battery to the solenoide/starter motor and earth leads are making good contact,
At the solenoide join together the both leads bypassing the solenoide using a pair of insulated pliers and the engine should turn over if the battery contains 12-14 volts, this can be done either with the ignition switch in the on/off position when ignition is off the engine will turn but will not start
Testimonial: "thanks, I did starter will not turn over, I will replace the starter"
SOURCE: i have cb sevenfifty f2n
bendix on starter bad or low voltage from battery could be rotted or broken wiring.check and clean wiring test voltage to starter for correct volts
