Question about Kitchen Ranges
The interior window of my KitchenAid KESH307GBL0 cracked. I ordered the part and I'm trying to replace it, but I don't know where the two angle brackets go and the two flat brackets. Also, it is loose at the vent.
I had to call a repair man to come to my house and fix it. Your services were not of help to me.
Posted on Feb 17, 2009
How do U remove the Interior light covers on a 2002 Dodge Intrepid. tried using a screwdriver and pushing left and it did not work
If you're talking about the map lights (2 lights in between driver and passenger)
If you have just the map lights, just pull the whole assembly out. Don't worry about anything breaking, just pull it down, just not at an angle or anything. It easily snaps back into place after. Bulbs can be removed once you have it out.
If you have an overhead console, you remove a screw towards the front of the overhead console Then just pull. If you're talking about other interior lights, let me know I'll let you know how to remove it.
Aug 10, 2011 | Dodge Intrepid Cars & Trucks
I just bought a 1988 Cadillac Brougham now i would like to fix a few electric things that don't work. Those are the interior lights the automatic door locks and the radio makes strange cracking noises....
the cracking noise in the radio sounds like a ground wire being on loose...the interior lighjts run off a fuse located under the dash next to your hood latch
May 18, 2011 | 1988 Cadillac Brougham
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to sears.com go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Jan 27, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Trying to replace drivers window lift motor. help!!
Tape and secure window, replace rivets with 1/4 nut and bolts.
Apr 28, 2009 | 1990 Buick LeSabre
Mixer has a broken gear or tooth in the head.
Hi. You have experienced the problem that many hundreds of kitchenaid mixer owners have. No doubt your mixer began having problems while you were mixing bread or cookie dough. Kitchenaid advertises that these mixers can handle these types of dough, the brutal truth is they cannot, for one very important reason. The cheap plastic transmission housing has failed, and as a result has caused damage to your mixer's transmission.
This cheap plastic part supports two of the most important shafts and gears in your mixer and has no business being installed in a high priced mixer. Heavy doughs place enormous stresses on these gears and shafts and this plastic part is not up to the task, Kitchenaid knows this of course, but refuses to issue a recall notice.
If your mixer is still covered by warranty, call Kitchenaid's so-called customer satisfaction dept. and demand a mixer replacement with a METAL transmission housing.
If out of warranty, unplug the mixer and don't use it. Remove the silver band from around the head of the mixer, then remove the four screws that secure the cover, remove it. At the front top of the mixer locate the transmission cover, if it's made of a shiny metal, you're in luck. If it's made of plastic, examine it carefully for cracks around the mounting screws or anywhere else on the housing. If you find cracks, you have found the culprit that has caused untold internal damage to yoúr mixer
If you are up to the task of repairing it, go to the kitchenaid.com website and do a search for your model's parts catalog. Download it, it will help with the disassembly and reassembly of the mixer.
You'll need to remove virtually all of the old grease. Remove the trans. components and wipe them clean, in order to correctly assess damage. When you determine which parts need replacement, you must insist on a metal housing when ordering parts. Try mendingshed.com for parts. You can also order parts from Kitchenaid...Just be prepared to wait at least a month for them to arrive from Kitchenaid! "For the Way It's Made"?
Finally regrease with Chevron FM ALC EP-2 a Food Grade lube.
Be sure to tell the people at Kitchenaid what you think of their cheap plastic housing!
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 05, 2009 | KitchenAid KP2671 Professional 6 Series...
Interior walls cracking...
i don;t think there would be a health issue involve.
the old fiber glass has been replaced with polyurethane foam now a days to replace the more dangerous fiber glass insulation.
if you can replace the plastic part that cracked open, that would much better.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
