Microsoft Windows XP Home Edition Logo
melinda green Posted on Feb 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do install a vga driver when computer won't let me connect to internet
Anonymous
Level 3:
  • Microsoft Master 2,878 Answers
  • Posted on Feb 22, 2013
Anonymous
Microsoft Master
Level 3:
Answers
2878
Questions
0
Helped
487987
Points
8243
I guessing you need the network driver. You must download via another computer / phone and copy over with a USB drive or burned CD.
1helpful
Internet won't connect
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima
2answers
My Lenovo mouse won't work. It connects and registers but won't move? Is there any help?
Try booting to safe mode and check if your mouse works inside safe mode.
Restart the computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight either safe mode or safe mode with networking. Hit enter.
Once you are inside safe mode, check if your mouse works. If it works, then you just need to update the mouse driver. You can use RadarSync to search and install the update into your computer. You better use Safe Mode with Networking because RadarSync needs the internet or even the manual updating process needs an internet connection.
I hope this helps!
David
I have an Acer 5520, using Empowerment Technology, running on windows vista, it can connect to my sky broadband, but then the broad won't connect on to the internet.
the obvious is restart the laptop, but alternatively what you can do is try and find an updated driver. to find out what driver you currently have and who makes it right click my computer and go to manage, then click device manager.
the driver your looking for should be under networking it should have something like "WLAN" the other should have "LAN" once you've found out who makes it go to their website download the latest driver and install test again.
My vga port doesn't work right
Your VGA connector has a broken solder joint on the video board or the mother board. This isn't an easy fix.
Suggest you look for a VGA to USB dongle or adapter instead. Install the driver, and you should be good to go. You'll just have to take your dongle along whenever you need a VGA connection.
2helpful
Hello, I am trying to install my d-link 125 usb adapter. I had to download the windows 7 driver from the d-link website, and now I am trying to install it to my computer. When I try to run the driver...
Use the following steps to let Windows do the installation for you.
Step 1: Use an Ethernet cable and plug your computer directly to your Internet gateway. Make sure Internet is accessible.
Step 2: Place your new adapter in the proper slot or port.
Step 3: With your computer running, a bubble message will appear stating that this device was not installed successfully. Left click on the message.
But if the message no longer appears, skip to Device Manager Installation.
Step 4: On driver installation failure, you can change the setting to use Windows Update by clicking Change setting...
Step 5: Chose to allow Windows to update your driver when it is not found on you computer.
Step 6: Once the driver installs successfully, close the window.
Step 7: Click/Right Click on the Network Icon located on the system tray to View the Available Wireless Networks. Find your personal Network and double click to connect. It should request for a wireless key, which by now should have been set up.
2answers
My computer won't connect to the internet wired or wireless. What is wrong, what can I do to fix this?
Hi.
First of all restart your PC. While the PC is restarting go to the modem and router and remove power from them for 30 seconds, then plug them back in.
Wait for around 1 minute for the router and modem to reconnect then go back to the PC and try to connect to the internet.
Please let me know how you get on.
Good luck.
1helpful
Need vga driver software for via p4m266-8235
HI!
need vga card driver! nothing to worry! i hav the solution that to solve ur issue!
first of all u need that u need internet connection for ur pc then download software named "driver genius pro" simply it may available in several links! then install it in ur system it wont download any virus! then connect internet open that software and it asssk u start scan allow taht to scan and it shows the list of driversto update ! then select vga in that list ! hot download tab below! that's it! ur vga driver is download and its located in my documents\driver genius folder thats it! ur problem solved! rate me if u like thiss solution!
Won't connect to my computer. I've had the printer for about 3 years, and all of a sudden it stopped connecting and i can't get it to connect again.
check printer connections and try again but if still not working go to control panel add and remove click to select program remove HP Photosmart then back to main window, insert the disk and install again driver, follow commands you see on the screen . but first unplug internet connection then exit anti virus before you start installing driver HP Photosmart .good luck
My smartbro hsdpa mf627 won't install correctyl in windows 7 computer it requires drivers which i don't have
first you have to download the windows 7 driver for the smartbro hsdpa mf627. since you can't download it in you pc cause you can't connect to the net because it isn't installed properly. You have to download it on other computer perhaps if you have a friend who have a pc with internet connection ask for him a favor for you to download the driver if he will help download it and save it on a USB flash disc and installed it in you laptop...Hope it helps you
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
