SOURCE: how do I create playlists for iriver H320
I too wanted playlist and found it out for v 1.25 K. I am not 100% sure about playlists for version 1.30E sorry, but you can try.
This is how I make playlists. Plug your iriver into your computer. Make a folder on your iriver, call it whatever you want. I called mine playlists.
Create a textfile in the folder, call it whatever you want and give it the extension the same as winamp gives. I think it is .m3u? Maybe .m3p? Anyway, find that out.
Open the file in notepad and put the path to the song. eg:
\music\rock\linkin park\numb.mp3
Add as many as you want one under the other. And make as many playlists as you want. Then unplug your iriver and let it rebuild. In music mode, you have to not be playing a song, so stop any music, then just press the A-B button and a list of the playlists should appear. Select one and away you go. If the press A-B does not work, try holding it. I can't remember as i havn't used mine for a bit.
Sorry I can't be most specific about your version. Or the extension of the file, I wrote a program myself to do the work for me. Check to see if it works for you, if you want a copy of the program I can send it to you. it is in .Net 2 so you will need the the framework installed.
SOURCE: iRiver H320 will not charge
did you turn off your USB so that the AC adapter can get through to recharge your battery.
SOURCE: CLUELESS IN NY, IRIVER H320
You have to hit the on button twice to show as connected,then you can manually move files to the root directory by going to the computer ICON on your desktop, finding your MP3 player,then clickto open the file - the find thefile you want to copy or move onto the MP3 and drag it into the MP3's main file NOT the file that says RECORD
SOURCE: Software Suit & Drivers for IRiver H320 MP3 Player
I have a US model of the H320 - You have to update the firmware, but the US model only got to 1.04 and it sucks - go to http://www.misticriver.net/wiki/index.php/H3xx_Firmware_Version_Information
and download the KOREAN version 1.31 version - it supports the US model. Once youupdate the firme ware on your H320, you will have to go the the main menu and switch the language to english.
SOURCE: iriver H320, software
this link is the h320 firmware http://www.iriverinc.com/search.aspx?SearchType=all&SearchTerm=h320+firmware
this link is for new battery http://www.ipodjuice.com/
FYI
and just to be on safe side those rare, hard to find songs/photos you have ..back it up to pc or flash drive....
your iriver / laptop/ pc or ipod never through this things away...if you have to always remember to take the hard drive out even if its blank...take it out
hope this is helpful
i forgot to say that i got an macbook and no windows on it
