Question about GE JKP15 Electric Single Oven
How do i install an oven thermostat?
I went to install the GE oven thermostat and when I was done all the eyes worked. When I went to try the oven I heard a loud pop noise. now nothing works. what happened?
  • 121 Answers
Shortcut circuit,check again how you install thermostat,and fuse in fuse box in house.
Posted on Feb 16, 2009
    President:
  • 2,976 Answers
You crossed wires or missed one and blew something out.
Oven will not heat
GE Oven: If it only gets warm, it is not getting 220 volts. It may only be getting 110 volts. First check your breaker (double pole) and reset it manually. Since it is an older oven, there may be a break in one of the wires or connections. A voltmeter will indicate just how much current you have. Be careful.
Mar 29, 2017 | Ovens
I have an older (1997) GE XL144 Gas oven. The burners light but the oven won't heat. Any suggestions?
IF THE PILOT LIGHT IS LIT BUT THE BURNERS DONT FIRE IT IS PROBABLY THE THERMOSTAT. FREEZE A LARGE OVEN PROOF BOWL FULL OF WATER PLACE IT IN THE OVEN FOR TEN MINS TO COOL THE OVEN TO BELOW ROOM TEMP AND THEN TRY THE OVEN IF IT WORKS FOR A SHORT TIME THEN STOPS CHANGE THE THERMOSTAT
Oct 01, 2010 | GE JGRP17 Gas Single Oven
My GE gas oven temperature goes up and down a lot
The Thermostat on the oven might have to be replaced. This part is usually located behind the knob with the temperature settings. There is always a fluctuation in the temperature(usually 5% before the thermostat cuts the burner of and then back on. Other things can also influence oven temperature, like air drafts(usually caused by unrepaired or construction gaps in the wall on back of the range, but more often its the thermostat that need replacing. The following link can provide you with a further description of how the oven works: http://www.partsquik.com/appliancerepaircenter/Gasrange.htm I think you can also purchase your thermostat at that same site.
Jan 28, 2010 | GE Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Temp 50 degree too cold need to adjust thermostat on JGRS14
ive installed 100 new thermostats over the years and they are set from the factory.no adjusting.now some knobs have an adjustment on them.and some times customers got knobs mixed up and got the wrong one one there.
Jan 01, 2009 | GE JGRS14 Gas Single Oven
Electric oven only works on Broil
just one light. if its not the element, then you could have the oven thermostat. check that
Oct 12, 2008 | GE JKP85 Electric Double Oven
GE glasstop stove problem
Try removeing power too unit for a couple minutes. You can due this by turning off breaker. Sometimes this will reset board. If not, you may need an ERC board.
Nov 04, 2007 | GE Profile JTP18 Electric Single Oven
Ge oven door locked
You oven is locked because it is self-cleaning. Some how the handle got moved and it initiated. You may need to let the oven finish self-cleaning. Usually, it can take about an hour to complete the process. Afterward, the oven will beep when done and your oven can be opened. Good luck.
May 29, 2007 | GE Profile JTP56 Electric Double Oven
GE JKP15 Electric Single Oven Logo
270 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
