Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
Use of electric?
My husband insists when we have the bulbs ON on our fireplace, it is using alot of electricity...I say NO MORE than when the TV is on! What do YOU think???
    President:
  • 1,902 Answers
The light on a fireplace uses less amounts of electricity then a TV actually. These fireplace lights are made to run off of almost nothing to produce light. Very enegry effecient that the green peace are trying to make these types of bulbs for Washers, fridges, outdoor lights
Posted on Feb 16, 2009
  • 121 Answers
Less then TV.
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
Our fireplace is 22 years old and we are not able to start the fireplace.
Is this a flame effect electric fireplace with a fan heater underneath it?
If it is, the bulb has gone. Remove the coal or logs and remove the cover. You will see the bulb.
Dec 29, 2015 | Heating & Cooling
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
How do I change lightbulb in Prolectric fireplace?
How to Change the Bulbs in an Electric Stove Heating Unit ...
? 3:26
https://www.youtube.com/watch?v=wICIyjUhHfs
Apr 17, 2013 - Uploaded by doityourselfstan
Easily restore them with a pair of light bulbs and a screwdriver.... electric fireplace and it came with a extra bulb but didnt say how to change it.
Oct 29, 2015 | Heating & Cooling
How do change a bulb in a classicflame 23ef010gaa
www.electricfireplacesdirect.com/changing-fireplace-light-bulb
Changing a light bulb within an electric fireplace is not hard, but we ... ClassicFlame23" Fixed Glass Spectrafire Infrared Quartz Electric Fireplace Insert - ...
Oct 29, 2015 | Cars & Trucks
I am thinking about getting the balmoral electric fireplace but i would like to see a manual
Bonnie, this fireplace just hit the market and to view an Owner's Manual you'll have to find one at a store that's selling the. However, as far as electric fireplaces go, you could look at any brand or manufacturer's Owners Manual and 98% of it would be the same. Some light bulbs turning on a rod to generate the flame look on a black background and faus glowing embers. Add a 1500 watt electric and you have it. I find it interesting that this electric fireplce is designed to be mounted on a wall, like a big flat screen TV and it has a heater. Problem with that is, all the heat stays on the ceiling.
My experience with selling electric fireplaces (From the most expensive to the cheapest) has not been good. All of them would function well for about 9 months to a year and then problems galore. with the exception of one or 2 brands are imported from China.
Hope this helped you. Thanks for choosing Fixya.
Aug 25, 2011 | Heating & Cooling
Light bulb reflection on wall beside fireplace
yes also try using a frosted bulb or the new mini twist bulbs
Jan 13, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Jamil nj
Hi Jamil
To help you out a little bit the Company you need to go through is a Vermont Casting or a Majestic Dealership... Alot of companies will only help you if you have purchased from them.
If you have a problem? Is there anything I can help you with?
Nov 19, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
257 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tim Whalen
Mack Baxter
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
