Question about HP Pavilion dv9000z Notebook
HP Pavillion 9925nr LCP monitor turns black
When I turn on my laptop the screen remains black but I could hear the start-up sound. I have to use a small penlight to light up its surface for me to see the icon to where I could enter my password. Thereafter, the laptop will run the way it is but still no visible display on the screen (remains black). On the other hand, when I connect an external monitor to it, everything are functioning properly. I could see the BIOS start-up and manage everything with the aid of external monitor. When I try to run its built-in web cam, it also gives me a good cam display (there's power on the webcam).
This unit was just given to me as gift to by my brother..Please help me!
    Sergeant:
  • 366 Answers
Check screen brightness.
On keyboard is normally activated by combined FN + Fx keys (F9 or F10).
Check your keytops and/or your user manual.
Using this feature you should be able to restore a standard contrast on your screen.
If it isn't working the only alternative is external monitor.
Posted on Feb 17, 2009
Power up computer...hear the windows jingle but the screen is grey
Try connecting an external monitor and see if that gives you video - if that works, your laptop screen may have gone bad and need replacing. If it does not work, check that you are not running in too dark a screen or the wrong mode. I dont know specifically which HP key code changes this but there should be pictures on your "F" keys to indicate this. Remember to push down the"Fn" key at the same time.
Jul 29, 2014 | HEWLETT-PACKARD Computers & Internet
My hp pavillion tx2500 black screen when turned on
If you connect an external monitor up and it is the same. seek a GPU reball repair.
Jan 30, 2014 | HP Pavilion Computers & Internet
Hp pavillion dv2 1005ee notebook PC goes black screen whenever i started it. What should i do? Also its keys not working while this problem.
h
to test if it is the lcd screen tis faulty or the inverter
plug in another monitor to the external monitor plug
when you turn on the laptop if the 2nd monitor displays the desktop your lcd needs to be replaced
if its also black your inverter needs to be repalced
aries
Oct 19, 2013 | Computers & Internet
My hp pavillion tx 2000 laptop is not working.............. when i turn it on, all the relevant lights comes on but nothing appears on the screen. i only get a blank screen.................. what could...
If you hear it start up and the lights come on, try hooking up an external monitor. When you do, be sure to push the Fn key plus whatever special function key shows 2 monitors on it so the output will be directed to the external monitor.
Sounds like the LCD screen might not be working.
Apr 20, 2011 | Computers & Internet
Can you help me, my laptop is hp pavillion tx 1110ca. the problem is when i turne it on the monitor display nothing all is black, what shall i do?
Are you hearing any beeps when you turn it on, or does it seem that the computer is starting normally but with no picture? If you have another external monitor, try plugging it in using a VGA cable from the laptop to the monitor. If it works, it indicates that the laptop screen or inverter require replacing, if not, the Graphics chip may have died.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | HEWLETT-PACKARD PAVILION TX1110CA LAPTOP...
My hp pavillion tx1320us is powering up but the screen remains black
try to turn off the laptop. Remove the cables and battery on the pc. Press and hold the power button for 8 secs. Then reinsert the cables and battery on the pc. Turn on the laptop and check if the screen still black. If it is, make sure that the monitor power light is on. Otherwise, there might be a problem on the video card. If you know how to reseat a video card, go for it and here is the step by step, instructions:
Turn off the laptop, remove the cables and battery, remove the screws at the bottom part 4 corner sides, remove the hard drive, remove the optical drive, then remove the video card and reinsert it. Then reinsert the other peripherals in descending order.
If still did not work, call HP and have your video card replaced...
Jul 27, 2010 | HP Computers & Internet
HP Pavillion Entertainment computer (laptop)
now u put out to another monitor by cable if u see screen in there ur lcd have problem, if black too it from ur motherboard , checking
Jan 14, 2010 | Computers & Internet
Laptop has power but screen remains black
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Jan 09, 2010 | HP Compaq 8510w Notebook
My monitor will not wake up
I wm having this same issue. Dis you ever get this resolved? princess242@comcast.net
Oct 17, 2009 | HP W2007 LCD Monitor
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
677 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
