Question about GPS
I have a new Garmin Colorado 400t GPS and I've used it to mark waypoints on a snow shoeing trail I frequently use. Is it asking too much of this GPS, or can I see a map of the snow shoeing trail I took yesterday when I am back at home? I know how to see the list of waypoints I've marked, but I want to see the actual map itself again.
  • 1 more comment
  • rateena Feb 16, 2009
    I've read the manual completely and it doesn't mention this option. The GPS came with "Trip and Waypoint Manager" software on a CD but it is only compatible with a PC and I use a Mac at home and at work. The description of the software says you can "transfer waypoints, routes and tracks between your GPS and a PC."
  • rateena Feb 17, 2009
    I managed to see a waypoint on a map by selecting Where To, Recent Finds,then clicking on a waypoint, but the map is 50& obscured by a dialog box giving the coordinates, etc. My Options are Project Waypoint and Project Waypoint, but neither of these get me back to the map.
    Thanks, I will try this!
    Brigadier General:
  • 5,158 Answers
I'm uncertain you could do that on your computer... unless you install the mapsource program that garmin uses... if you just want to see the map again on your gps you can shut off the waypoints in your options menu
Posted on Feb 16, 2009
  • 13,433 Answers
Hey,
the manuals for your unit are available here
http://buy.garmin.com/shop/store/manual.jsp?product=010-00622-45&cID=145&pID=11022
I'm not sure if this is possible on this unit but you can try. I will also have a look into it.
  • Ekse Feb 16, 2009
    Looking at the manual page 35 in pdf reader or 25 in paper.
    the Tracks Setup might be a solution to you.
    Top Expert:
  • GPS Master
  • 77,544 Answers
U can call Garmin direct for free tech assistance, they can answer this question quickly with no guessing, here is the link to the site for this free assistance.
https://my.garmin.com/mygarmin/marketing/register.htm
Posted on Feb 17, 2009
Pc does not recognize colorado 400t via usb port
Try updating your device software : http://www8.garmin.com/support/collection.jsp?product=010-00622-45 Also, update your Webupdater software as well. And if neither works you may want to try a separate USB port as well. Hope this helps!
May 13, 2011 | Garmin Colorado 400t
My Garmin Colorado won't go past load maps....I tried new batteries and still no difference....please help before I throw it against the wall
I had an Oregon 200 and i had the same problem. It ended up the brightness was turn all the way off and then i locked it.
May 07, 2011 | Garmin Colorado 400t
Problem with our Garmin you can turn it on and it will not do anything but display Garmin name and will not turn off. Have changed batteries, any ideas???
It sounds like your Garmin has a corrupt file or file system. This is common when using bird's eye imagery with unsuspected shut-downs.
Try doing a soft reset of the Garmin:Warning: This procedure will delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
1. Power the unit OFF
2. Hold down the two Soft Keys for 2 seconds
3. While continuing to hold the 2 Soft Keys down, press and hold down the Power button for an additional 5 seconds
4. Release all buttons, and select YES to the prompt asking "if you want to clear all user data?"
This form of reset does not seem to reset all of the settings to factory defaults, just a few of the basics like Time Zone and Language, the remainder of the settings are still taken from your existing profile files.
Once you have completed a reset remember to place the Colorado outside in a stationary position for 20 minutes in plain view of the sky so that it can rebuild the almanac before using it again.
Note: Holding down both soft keys and the select button in a similar fashion seems to do a similar reset to the Colorado. This may be a master reset.
If the problem still persists, try this as a last ditch effort.
Warning: This procedure may delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
If you can't get your CO to start properly and it will not go into USB storage mode when connected to your computer you can try this as a last ditch recovery. It worked on a 400t that would freeze when loading maps and soft/hard resets didn't not work, I've also used it to recover a Colorado which refused to boot because of a bad gpx file.
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > cd c:Garmin
At the next command prompt type the following command without hitting enter:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
zip.png Colorado_Mass_Storage.zip
Feb 07, 2011 | Garmin Colorado 400t
Gps is only accurate within 100+feet while geocaching. Problem started just in the last month before that it was dead on. I've replaced battries and recalibrated but still no good.
The GPSr needs to build a new almanac. There are a few steps to do this properly.
1. hook up your Garmin to your PC and copy your wanted files. (Waypoints, geocache log, maps)
2. Do a soft reset of the GPSr.Warning: This procedure will delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
for this
3. Build a new almanac (Make sure you have fresh batteries)
Feb 03, 2011 | Garmin Colorado 400t
Compas is not accuate
When using the compass on the Garmin Colorado 400T it is recommended that you actually calibrate it before each use, you probably just need to be recalibrate. Also make sure that there is no magnetic tools around the device.
Hope this helps!
Dec 08, 2010 | Garmin Colorado 400t Handheld GPS Receiver
Can't seem to delete my wayward marks.
Delete your waypoints?
Find page > Waypoints
Scroll down to the waypoint you want to delete
Press ENTER and the waypoint details will come up
Move your toggle to the left to highlight the DELETE tab at the bottom of your screen
Press ENTER, screen popup asking "Do you really want to delete waypoint x? Highlight YES and press ENTER.
Nov 29, 2009 | Garmin eTrex Legend GPS Receiver
Wrong language on garmin oregon 400t
I called Garmin for this very same reason. The answer is; while your GPS is off place your index finger in the upper left of the screen, turn on the GPS, a screen will come up and ask if you want to clear the GPS (or something to that effect), say yes. (Yes is the top button) Then you can choose english. YAY!
Rin
May 03, 2009 | Garmin StreetPilot 2720 GPS Receiver
How top use a garmin etrex g p s
Your manual will tell you how to use waypoints, mapping to a waypoint, and how to do backtracking. If you don't have the manual, you can download it from the Garmin website www.garmin.com. Under Products > On The Trail, find your model of GPS. On the far right of the page, you will see a link for the manual.
Oct 15, 2008 | Garmin eTrex Legend GPS Receiver
How do I enter gps coordinates into my Etrex H
Mark a waypoint, and then edit the waypoint's co-ordinates. You can also create a waypoint in Mapsource and then transfer the waypoint(s).
Jun 29, 2008 | Garmin eTrex GPS Receiver
Plotting Waypoints
Here's the link to the user manual if you need it; http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf Garmin says; To manually enter in the coordinates for a waypoint on the 60 or 76 -series units, use the following steps: Press and hold the 'Mark' button. Use the up arrow to scroll up to the "Location" field and press 'Enter'. A new box pops up to enter in the new coordinates. Go to "OK" and press 'Enter'. Select "OK" at the bottom right corner to save all changes. Hope this helps :)
Jul 17, 2007 | Garmin 60 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
