Question about Cisco 7960 IP Phone
Trouble forwading a call on a cisco 7960
I currently have it set to forward to my cell phone. I want to change it to forward to another number. No matter what i do it still forwards to the old number. Am I doing something wrong?
    Problem Solver:
  • 10 Answers
If your primary database is not up on Cisco Call Manager (CCM) then the phone doesn't accept any changes in configuration, all call functions work.
Posted on Mar 19, 2009
Cisco 7960 turns it self off
Do you have a power block for the phone or are you getting power from a POE switch via cat5 cable?
How do you know you purchased a working phone? When was the last time the phone worked properly?
Any other information you can supply about your VoIp setup would help us troubleshoot the power issue with your phone.
Jul 17, 2012 | Cisco 7960 IP Phone
My cisco ip phone 7960 is stuck in boot up mode after performing the soft reboot. i press 123456789*0#
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
Mar 15, 2011 | Cisco 7910 IP Phone
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
How can I upgrade my frimware on the Cisco 7960, it is a 3 and needs to be 7?
Best and easiest way is to plug it into a newer callmanager. The firmware will be upgraded regardless of wether or not it is able to register.
Sep 02, 2010 | Cisco 7960 IP Phone
I have tried repeatedly and I can not get my phone to set up. Not even sure what the phone # is. I need it from the start to the finish. I also need my work # to forward to my cell phone 817-713-1767.
What service are you using to provide your SIP? The 7960 requires a call manager, or other network bootable server to make the phone function. It will not function on its own.
Aug 25, 2010 | Cisco 7960 IP Phone
Cisco 7960 is not registering, says 'Requesting line status'.
Then contact your service provider, this issue is from there end, thanks!
Jul 29, 2010 | Cisco 7960 IP Phone
Need to know the purpose and operation of the
it is used to hookup a number pad (for example attendent console)
Jul 14, 2010 | Cisco 7960 IP Phone
Ringer is not working. Phone is not on DND. Cannot select and play a ring - message "the key is not active here"
Hey, Can you check if you have forwarded the calls on any other number. In that case it wont Ring.
Feb 12, 2010 | Cisco 7960 IP Phone
7906G Home VOIP installation Problem
Then you need power adapter for Cisco 7960 IP phone ( -40V DC).
Cisco phones work best with Cisco, and sometimes ONLY Cisco switches.
One question which voice gateway you will use for your 7960 VoIP phone calls to go through ?
(AT&T probably supports only their IP Phones with special and usually hidden settings from end user)
Jan 17, 2009 | Cisco 7906G IP Phone
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Cisco 7960 IP Phone Logo
273 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
