Question about GE Optical 98802 Mouse
Can't relink after battery change
Have changed batteries many times but now can't relink. do i need to buy new receiver and mouse? what might i be doing incorrectly?
    Problem Solver:
  • 5 Answers
Go on line and use Google to find the part and download the instruction manual.
dwilli10
Posted on Nov 29, 2009
How do I connect my Logitech wireless mouse to my computer
I use Logitech wireless mice and so does my wife. After a battery change you have to reconnect the mouse with the wireless receiver
. First push the button on the receiver, then push the button on the bottom of the mouse. It should connect and you will be ready to go. If this doesn't get the mouse working, you may have to unplug the mouse, then plug it back in the USB port, then reconnect to the receiver. Hope that helps.
Sep 30, 2014 | Logitech Cordless Mouse
GE wirless Keyboard & mouse 98552: Worked great, changed mouse batteries, now it won't reconnect. Press the connect button on bottom of mouse... no luck?
You also need to click on the receiver button. After the receiver button is clicked then you would need to click the mouse button located under the mouse. If all of this was done try replacing the batteries again with a new set of batteries. I've seen new batteries not work before that has died while sitting in it's package.
Nov 20, 2010 | GE Computers & Internet
I have a Microsoft Wireless Desktop Receiver 3.1 unit which works both my keyboard and Wireless Laser Mouse 5000. My mouse is not working and I've changed the batteries 3 times. Can I buy a replacement...
I have the same system. Mouse can be ordered, but not easily. Make sure mouse is not working.... i almost made tour same mistake. In my case, the mouse plug (from computer to wireless receiver) had become unhooked. All i could see is that mouse was communicating with wireless receiver but appeared to be frozen. If you can reset receiving channel, and see that receiver acknowledges presence of mouse, you may have my same problem. Also, if you can see that the laser light is working, mouse is probably ok, and batteries are good.
Feb 15, 2010 | Microsoft Wireless Optical Mouse USB...
Changed battery and now doesn't work. red light is on bottom of mouse, but curser won't move on screen
There is a reset button on both receiver and mouse you must reset every time you change batteries. Normally the receiver one first.
Jun 26, 2009 | Logitech Cordless Mouse
Where does the batteries go on my ge optical wireless mouse?
On the bottom of the mouse there is a snap-off battery cover. The batteries go in the holder below this
cover. Take care to install batteries with the correct polarity. Push in from the indent with a thumbnail
toward the slot in the cover and pull the cover up. Do not use a tool as the tab that holds the cover closed is easy to break. Do not pry up on the cover from the cover slot either. After batteries are changed the mouse and receiver will likely need to be relinked.
To link the mouse and receiver, turn on the on/off switch on mouse bottom. Plug in the usb to pc.
Boot pc. Hold down the link button on the bottom of the receiver until the led blinks. Release.
Quickly push in the link button on the bottom of the mouse. When the receiver led flickers, the
mouse is linked. The receiver led will flicker when the mouse is used.
May 27, 2009 | GE Wireless Optical Mouse
Mouse`slowly quit working
Maybe your mouse in malfnctioning. It depends how it is use or the product itself. You must configure the mouse on control panel.
May 18, 2009 | GE Wireless Optical Mouse
97990 Rev. 4
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 30, 2009 | GE Wireless Optical Mouse
Wireless mouse stops working
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver burron and then press the button on the mouse. This should be fdone when ever you change batteries or glitch. Hope this helps you. Bud
Dec 30, 2008 | Computers & Internet
Kensington Mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Nov 28, 2007 | Kensington PilotMouse Laser Wireless...
Warning: receiver channel changed - wireless keyboard and mouse
I contacted Gaeway Support. They quickly answered and suggested that I change the batteries in my wireless mouse and/or keyboard. I did. It was the mouse. As soon as the new batteries were in, the popup went away and stayed away.
Jan 07, 2007 | Gateway 2520915 Keyboard
GE Optical 98802 Mouse Logo
97 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
