Question about Tappan TMT104E1 Microwave Oven
Filter replacement on my tappan tmv151fs the manual saysto pop the top vent off to put in the filter but it doesn't move any suggestions
  • Tappan Master
  • 9,098 Answers
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
supply.
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Posted on Feb 17, 2009
Tappan Electrolux tmv151fs microwave/rangehood. turntable and cavity light intermittent (but work/fail in unison), all else work ok
Either a wiring problem or worn contacts on the relay that powers the two would be possibilities.
Nov 24, 2016 | Microwave Ovens
Everything on our microwave works except the most important part-its not heating. TMV151FS
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 09, 2011 | Tappan Microwave Ovens
My Tappan TMV151FS MIROWAVE OVEN DOES NOT WORK THE MESSAGE READS (SE) IN THE LCD WINDOW CAN'T LOCATE MY OWNERS MANUAL CAN YOU GIVE ME ANY INFORMATION ON THIS PROBLEM THANK YOU LEO LAFLER
"SE" means you have a shorted membrane keypad.
The most economical repair (and a pretty simple one) is to replace your entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Model TMV151FBA is black and model TMV151FSA is white.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You would order one of these here:
PART DESCRIPTION COST
5304456080 Control Box, assembly, black $145.14
5304456081 Control Box, assembly, white $149.42
Sep 07, 2010 | Tappan Microwave Ovens
Tappan over range has no heat!
You have a bad high voltage diode, bad filter capacitro or a bad magnatron. The diode and capacitor does not cost very much. You can get them at www.mcmelectroncs.com . Replacement would mean removing the unit from under the counter, remove the case. Locate the diode and capacitor. They should be near the power section and the diode is attached to the chassis and one side of the filter capacitor. After replaceing both parts if the unit will not heat you would need a new magnatron. The part is fairly expensive but depending on the cost of your unit it may pay to replace it. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Jan 01, 2009 | Tappan Microwave Ovens
Microwave Ovens Logo
268 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
