Question about Linksys Wireless-G WRT54GS Router (e125894)
Link Sys wireless G router, connects with laptop, not desktop
I have AT&T as DSL service provider.
I FINALLY got my laptop working to connect with my Link Sys wireless router. My desktop "sees" the connection, makes the connection, but cannot get to the internet.
It is set to WEP, not sure what else to do.
The laptop is on Windows VISTA, desktop, Windows XP if that matters. it worked fine before I moved and hooked into AT&T.
thanks in advance for any help! I need both PC's for my work
  • 2 more comments
  • robininhisha Feb 17, 2009
    The laptop is only 1-1/2 years old. I am not sure how to check to see if the modem is set to ppoe??
    i will try it and let you know..have to move my desktop back to the modem and that will take a little while. thanks so much!
    and you realized that my LAPTOP is connecting OK to the wireless router, but it's my DESKTOP (which is about 3 years old and upgraded memory) with Windows XP that is not connecting to the router.
    it was prior to hooking up to AT&T software.
    just wanted to be sure you knew that my laptio IS connecting OK
    thanks again!
  • Stan Moffett May 11, 2010
    how old a laptop and what type of modem and is the modem set to ppoe
  • 75 Answers
First unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Posted on Feb 17, 2009
  • Stan Moffett Feb 17, 2009
    pls rate me and if anything futher post back you can also hook up to the modem with laptop if your laptop has the right cable connections
    ok try changing out your ethernet cable if you are useing usb to connect go to ethernet cable Pls rate this
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
I cant get this sylvania 7 smartbook , model # synet07wicv to get internet.
Dec 25, 2011 | Sylvania G-Netbook
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this "laptop" to enable getting wireless connection of internet?
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
Jul 29, 2011 | Dell Inspiron 5100 Laptop
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
My desktop uses a DSL internet connection but my lap top will not pick up the signal from it to connect even when I have it sitting right next to my desktop. If I actually unplug yellow connection cord...
Having your laptop sitting next to your desktop will not let your laptop connect to the DSL link.
You need what's called a Wireless Router. (assuming your laptop has a wireless adapter, if not you'll need a network cable for that.
1. Go to the store, buy a wireless router
2. install router in between your DSL modem and the computer.
3. Plug the WAN port into the DSL modem (cable is usually included with the router)
4. Plug the desktop into the back of one of the ports of the wireless router
5. Run the setup disk
6. For manual configuration of the router you can usually go to: 192.168.0.1 or 192.168.1.1 or 192.168.2.1 depending on the brand)
7. If you don't know anything about networking, let the install disk do all the work.
8. Follow the instructions on what it tells you your configuration is for your wireless network.
9. Go to your laptop, apply said instructions.
10. ???
11. Profit.
Dec 02, 2008 | Acer Aspire 5050-3242 Notebook
Lan
Okay so if I understand your question....your desktop has DSL and you want to connect your laptop to the same DSL connection? If that is the case then what you need is a router. A router will share the DSL connection between the desktop and the laptop. A wireless router will allow your laptop to surf wirelessly if it has a wireless adapter or you can plug it into the ethernet port on the laptop. You can purchase one here. The instructions are pretty simple and straightforward and should be included with the router.
Jun 25, 2008 | Dell Latitude D600 Notebook
No internet connection on my laptops
Please understand as I get very basic to start but things very obvious to you I cannot see.
Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
If necessary unplug the router and plug the computer back into the original cable until we get the router working.
Dec 26, 2007 | Linksys Wireless-G WRT54G Router
Setting up a wireless router
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Nov 30, 2007 | D-Link DI-624M Router (DI624MRE)
Linksys Wireless-G WRT54GS Router (e125894) Logo
117 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
