Question about Honeywell Programmable Thermostat Heater
Heat will not shut off
I replaced a honeywell CT70 thermostat with a honeywell rth3100c. My wiring from the old stat was: X= blue, W2= white, R=red, G= green, O=orange, Y1=yellow, and E=brown. My new stat has E, Aux, Y, G, O, L, R, B, and C. I hooked up the new one E=brown,Aux=white,Y=yellow, G=green, O=orange, R=red, and B=blue. The AC worked fine but when the heat is turned on the fan comes on right away and the heat doesn't shut off automatically. Any ideas on what I did wrong?
    New Friend:
I would not connect the X (blue wire) to the B terminal. I would connect the X (blue wire) to C. Attaching X to C is actually "Optional" if your thermostat has batteries, and I know the RTH3100C does have batteries. You could just tape it off. The other wires are on correctly.I hope this works for you.
Posted on Jan 03, 2013
  • 1,902 Answers
Take white off of Aux, and attach it to L
Posted on Feb 16, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 16, 2009
    Sorry whit eneeds to go to common you need a common wire
  • Jeremy Reddick
    • {Terminal
      name}, {color}, {function}
    • (R),
      Red, hot side of transformer.
    • (C)
      Common side of transformer (See B)
    • (Y),
      Yellow, Compressor activity (cooling or cooling and heating on a heat pump).
    • (W),
      (W1), (W2) White, "Heat" (gas
      , oil burner
      , electric heat,
      (auxiliary heat on a
      including defrost output from the outdoor unit to activate electric
      heat and turn on the AUX. heat lamp). Note: some thermostats require a
      jumper from "W" to "Y" for heat pump operation.
    • (G),
      Green, furnace blower fan. (needed for air conditioning, heat pumps and
      some electric furnaces). NOTE: on most thermostats the "G" and "Y" are
      connected together at all times when the fan switch is in the "Auto" mode!
    • (O),
      Orange , Energize to cool (used for reversing valve on heat pumps)
    • (B),
      Blue or Orange, Energize to heat (used on some systems, Rheem/Ruud is notorious
      for this).
    • (B)
      or (X), Blue, brown or Black, common side of transformer. Needed on some
      electronic thermostats or if you have indicator lamps. Do not confuse with
      (B) Reversing valve (energize to heat) above. York and Trane like to use
      (B) as common.
    • (E),
      blue, pink, gray or tan, emergency heat relay on a heat pump. Active all
      the time when selected, usually not used.
    • (T),
      Tan or Gray, outdoor anticipator
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Changing From Trane to Honeywell
Color ---> New stat terminal
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Jun 13, 2013 | Honeywell RTH3100C - Digital Heat Pump...
I have a Honeywell LR1620 Thermostat that I am replacing with a Honeywell RTH230B. I se where all the wires go to on the new thermostat EXCEPT the blue wire that is attached to the "W2" terminal...
If your old t-stat had a W2 terminal with a blue wire connected, and your new t-stat does not have a W2 terminal, then you may have purchased the wrong t-stat. The old is a 2 stage heat where your new is a 1 stage heat. 2 stage heat means the tstat will engage 2 heat elements, then if it continues to get cool inside, the Tatar will engage w2 and the remaining 1 or 2 heat elements. If you want it like it was to begin with, you'll need a 2 stage heat 1 stage cool tstat.
Oct 10, 2017 | Heating & Cooling
I am wiring a honeywell thermostat model number ct87n if I select fan on the fan runs when out on auto /heat nothing but if I put on auto / cool and adjust the dial to a low setting the hea comes on....
there is it all depends on how many strands of wire are in there, they start at 2 wire and go to i think 8 wire and maybe more.
The wires are as follows:
1. red = power to stat.
2. green = fan control
3. blue or yellow = ac
4. white = heat
w1 = 1st. stage heat
w2 = 2nd. stage heat.
i am on line if you have any questions. wally
Feb 22, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Jul 24, 2009 | Heating & Cooling
I had an old thermostat that i had to change need wiring diagram
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Dec 20, 2008 | Honeywell Programmable Thermostat Heater
I am replacing a white rodgers thermostat with a honeywell rth3100c. i have matched my wire as e (brown) to e w2 (white) o aux y (yellow) to y g (green) to g o (orange) to o l blank r (red) t r b blank c...
Blue (C) or sometimes (B) should be your common wire. Look at your schematics and locate common. Your Brown wire is (E) and is emergency heat, white wire (W) is Auxilary Heat, green wire (G) is fan relay, red wire (R) is power, yellow wire (Y) is Cooling and orange wire (O) is reversing valve.
Dec 02, 2008 | Heating & Cooling
Heating & Cooling Logo
684 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
