Question about LG WD-3632HW Front Load All-in-One Washer / Dryer
LG model WD3632HW OE lite is on and will not drain
Hoses and strainer are clean
5 Suggested Answers
SOURCE: lg wm2277hw
Followed suggestions for LE message and it solved my problem with the OE message - cleaned the drain filter located on the front of the machine near the floor.
Posted on Sep 03, 2007
MNTECH
  • 1543 Answers
SOURCE: lg washer serial # 308kw00211
That OE is really DE (drain error). Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. (at least if it is not plugged) Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. You can remove the pump without taking the front off the machine. Do an "Ask Me" if you need to do that, and I'll give you further advise.
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: I have the Crosley cfw8000gr front load washer and
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
Posted on Aug 27, 2009
  • 1382 Answers
SOURCE: LG washer with OE error
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Posted on Jul 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
What do we do after replacing the pump on an LG frontload washing machin, yet still get error message OE?
Assuming you cleaned the pump strainer?
Likely the drain hose leading from the pump to the drain, the section
inside the cabinet that "u-turns" back down is plugged up with
junk.. I had to remove the hose from the machine and force water
thru it at a outside faucet to clear what looked like a turd from the
inside of the drain hose..My shop vac could not dislodge it..
Aug 16, 2014 | LG Washing Machines
Machine reads oe and wont finish the rinse cycle
drain strainer maybe clogged or drain motor dead or there is obstruction inside check hoses
Aug 31, 2013 | LG WM Washing Machines
Lg frontload clothes washer WM0642HW won't drain during wash cycle. says OE code.
Drain strainer maybe clogged or drain motor dead or there is obstruction inside check hoses
Aug 27, 2013 | LG Washing Machines
Washer stops says"OE"
What Model #. OE is a Long Drain Time Fault. Check your pump strainer on the bottom of the washer behind the small trap door.
Apr 25, 2010 | LG Washing Machines
I have the Crosley cfw8000gr front load washer and dryer. The washer stops when its ready to drain and the letters on the dislay say OE. I have cleaned all of the filters and hoses however it still stops...
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Apr 01, 2008 | Washing Machines
LG WD-3632HW Front Load All-in-One Washer / Dryer Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
