Question about American Bath Home
Angle base cracks in factory seams
Your noe angle base has factory cracks along seam and is less then 2 yrs. old. i purchased at home depot in lawnside n.j.
  • heatguy May 11, 2010
    more then likely caused by improper installation.too many variables to list
  • 547 Answers
Contact manufacture ask for replacement as it is most likley defect substandered matriels thay may be intrested in the fault in there product and may give you discount on new if you use there product again.
thank you for useing fixya please rate me
Posted on Feb 25, 2009
  • albert getty
    albert getty Feb 25, 2009
    try to talk to someone in product testing thay might be more intrested then the person at front desk the them thay might want to look in to this as thay may have this same product installed and may fail
HOW DO I PREVENT AND GET RID OF CONDENSATION IN HADLIGHT ASSY
Condensation in a headlight assembly usually means a crack or split in the assembly somewhere.Remove the assembly and use a hair dryer to dry it out. Go along to an auto supply store and get some "seam seal" (not silicone) and a silicone based lubricant.Spread the seam seal around the join in the headlight assembly and let it dry up.This is usually overnight.Take the silicone lubricant and apply it to the rubber gasket around each light bulb.DO NOT get the lubricant on the bulbs. Replace the bulbs in the assembly.This should solve your problem. Good luck
May 05, 2014 | 2006 Chevrolet Equinox LT
Pump leaking from base
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is about $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt to prove it,Karcher will replace the whole Pressure washer under warranty.
Jul 06, 2010 | Karcher K2.26 Electric Power Washer
My mask is leaking at the inner seam
I would clean the area really well and use a silicone glue. It's available at Home Depot, Ace, etc. and provides a flexible, water proof seal. Enjoy the reefs!
Mar 14, 2010 | Cycling
How can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Feb 11, 2010 | Sony Televison & Video
Cracked seam inside Microwave
It will have to be sanded smooth and clean and dried thoroughly.
Then if the steel seam is actually cracked / separated, then you can apply a very thin bead of steel-based epoxy "J-B WELD". When it dries thoroughly, you can sand it smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If it's just the paint that's cracked, it will have to be sanded smooth and clean and dried thoroughly.
Jun 27, 2009 | General Electric Microwave Oven
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
There is a knocking noise when drying clothes
Look for a crack at the welded seam of the dryer drum. Noise maybe coming from the crack when it passes over the drum support rollers. Check front and back side of the seam. Solution is to replace the drum. If this is not found, please describe your symptoms in more detail.
Dec 23, 2008 | LG DLE0442 Electric Dryer
Altec lansing avs 200
These speakers are factory molded, technically the only to open them is by breaking the casing......fear not, I will offer an easier soultion which should not damage the case.
Using a heavy screwdriver handle sharply strike the seam on the base of the speaker, after seneral raps along the seam the case should begin to separate....after repairs use the old standbye superglue, Shouldnt be much evidence !
Ed Meyer
AACS
alwaysaffordablesolutions.com
Jun 10, 2008 | Altec Lansing Multimedia Computer Speakers
Home Logo
44 people viewed this question
Top American Bath Home Experts
Donni Steen
Tom Chichester
Are you an American Bath Home Expert? Answer questions, earn points and help others
