Our Sony KDP 65BR2 65" Digital HD Projection TV had curved lines on the black screen for months. It then began to turn blue after a few seconds and turn off. At first you could just turn it back on. Then it got to where you had to unplug it to get to come on and it would repeat the blue screen a couple of times before it would stay on. This went on for several months. Then when this happened we would have to unplug it several times before it would stay on. The last time we turned it on was the end. Nothing will help it turn on anymore.
Is there a solution? If we need a part what is the part number and can anyone install it or does it take a technician. We live in a remore area and it is hard to get a service man to come out here. I have called several places and no one will.
Incidentially this was purchased from Circuit City and had an extended warranty. Had being the operative word.
You have a shorted blue CRT (picture tube) the lines you saw are called retrace lines and when you can see them, there's either a mis-adjustment of the screen settings to the CRTs or a circuit malfunction or in your case, a bad picture tube. If your TV's serial number starts off with 90..... then you have the defective CRTs Sony put in hundreds of thousands of their projection TVs from late 2001 thru 2003. They made a very poor attempt to resolve customer complaints for a short period of time but now they have left many consumers hanging because they claim they have no more of these CRTs left.
Also, regarding your Circuit City wrranty. Don't give up. These warranties are held by third party insurers mainly G.E Extended Warranties who are stalling for time until a bankruptsy judge forces them to take care of their customers. Contact your state's attorney general to complain and get info on how this will be resolved.
Good Luck!
michtech
Was this helpful?
Yes
No
Popular Solutions for Sony Grand WEGA KDP-65XBR2 65
Sony Grand WEGA KDP-65XBR2 65 in. Rear Projection Television
KDP65XBR2 TV, When turned on, no picture and there is a red light which blinks times.it has sound ....
(More)
KDP65XBR2 TV, When turned on, no picture and there is a red light which blinks times.it has sound . somebody help me please
I have a Sony KDP-65XBR2. It powers up fine, then shuts off after 5 steady red blinks on the...
(More)
I have a Sony KDP-65XBR2. It powers up fine, then shuts off after 5 steady red blinks on the standby light. It has good sound in the speakers, and the picture displays fine, old bulbs will probably need to be replaced. The unit will stayed powered up for about 5 seconds until it shuts off. While the unit is powered off (with the power button pushed to the ON position) the TV will then give 6 very fast blinks. I noticed that when I first plugged the TV in powered it up, I got 11 red blinks from the standby light. Any suggestions???
I have a Sony KDP-65XBR2 tv that i am trying to fix.The tv will turn on with just a color display on...
(More)
I have a Sony KDP-65XBR2 tv that i am trying to fix.The tv will turn on with just a color display on the screen but then turns right back off.The green tube is not coming on at all and i have redone all solder joints on all 3 tube boards...Found resister #3935 burnt on the CB board..Replaced it only to have it blow time i turned set back on.I have checked and there is high voltage to all three tubes as well as the heater voltage..
My ? is why is r3935 blowing and why is green tube not even coming on...anyway to test to see if the tube is bad??
We have a TV with this problem: http://www.fixya.com/support/t1673203-sony_kdp65xbr2 I located both...
(More)
We have a TV with this problem: http://www.fixya.com/support/t1673203-sony_kdp65xbr2 I located both of these PC boards "G" and "D" but the Caps are all C follow by a 4 digit number so I can locate the components you refer to. Can you help any further.
