Question about Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers
Rear S-Air speakers cutting in and out
Hello all,
I have a Sony Bravia HDX-576WF home theater system, with the S-Air wireless speakers and receiver. The wireless speakers keep cutting in and out. This happens regardless of what mode the system is in (Pro Logic, Multi). When the speakers cut out, the green LED on the front of the wireless receiver flashes on and off (which I believe means it is looking for a signal; it glows steadily green when the speakers are working). The switch on the back of the S-Air receiver is switched to "A", the only switch position in which the speakers will work.
Is there anything I can do to fix this problem? The S-Air receiver is only about 10 feet away from the system, and is in clear view (not buried by magazines, fast food bags, cats, etc.). I have placed it low, on an end table, and high, on a bookshelf, and the problem still persists.
Any help would be greatly appreciated. Thanks!
  • kshurdler May 18, 2009
    I have a similar problem. I just switched out my HDMI cable for a Sony brand HDMI cable and still have my problem (S-Air works in AM/FM and Non-HD channels and not for HD channels, DVD or in AM/FM when TV is turned on). Although my problem is a little different. I just have the HDMI cable connecting my home theater system and my tv. As soon as I turn the TV on the green light blinks and the surround speakers stop working.
    Everything seems to work just fine when I just use my video (red, white, yellow) cable instead of HDMI. The only thing that doesn't work is the radio display doesn't display on the TV. Any ideas on my issue?
    Sony support wants me to ship the system back to Texas. I think I may just replace my HDMI cable with component and be done with it though.
    Am I really missing that much if I use component rather than HDMI?
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
Posted on Feb 22, 2009
    Problem Solver:
  • 5 Answers
With H.D.M.I. cable you still have to hook up audio out from t.v. or dvr converter box to the surround system audio in.
Also wireless ohones, baby monitors etc. can interfere with signal. You can try using b. or c, channels, and repairing. Both main unit and s- air sub unit must be on same channel a,b, or c.
Posted on Feb 28, 2009
The S-Air receiver for this unit DAV-HDX576WF cuts out when i bring it upstairs. Ive read that it should go alot farther. Please Help!
Most of the distance mentioned in ads and manuals are direct line of sight. As the number of walls between the transmitter and receiver increase the range keeps dropping drastically. Its not the distance but the obstacles that come in between that matter.
Aug 22, 2011 | Sony BRAVIA® DAV-HDX576WF Theater System...
I bought a new Magnavox LCD HD TV and need an audio system
Their not showin it on this site, but go directly to the Sony site and look up the Sony Bravia DAV-HDX 285 system. Its an awesome inexpensive system (compare to other systems). Features everything you need including the reciever and 5 wireless speakers and 1 wireles woofer. I love the wireless stuff because your not trying to hide wires, it looks nice, and its easy to install. Hope this helps.
Oct 30, 2009 | Audio Players & Recorders
MY S-AIR SPEAKERS ARE NOT WORKING
Are the wireless turned on and configured to work?
Check settings and batteries.
Maybe it would be best to run wired?
If not try what I have said before.
Hope this helped
-Ryan
-Please Vote if this helped.
Feb 18, 2009 | Sony Bravia DAV-HDX576W Theater System...
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
Jan 10, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Sony bravia wireless speakers won't pair? ANy answers?
You might try setting the wireless to a different channel. Mine did not work at all on "A" but worked fine on "B".
Dec 26, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Nov 29, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Aug 11, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
6,058 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
