Question about Numark TTX1 Turntable
How to adjust cartridge on Numark TTX so it does not rub record.
The cartridge is rubbing on the record. I know this because there is paint rubbed off on the inside (left) rear cornor of cartridge. Not to sure about adjusting the device. Please help.
djproaudio
  • 515 Answers
SOURCE: numark ttx with variable torque, platter turns slowly, weak torqu
More than likely one of the Drive IC's has failed, and needs to be replaced.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
wiznet2000
  • 86 Answers
SOURCE: Numark TTX-1 turntable starts slow but then is okay.
A drop or two of light oil at the center of the spindle will surely solve the problem.Remove the platter and check if its clean
Posted on Jul 06, 2009
SOURCE: My Numark TTX Turntable turns on but wont spin
It's probably the motor drive IC Chip.
Send it to us for speedy, cheap repair.
http://www.reflexdjsuperstore.com/Service-and-Repair-p11441/
Posted on Aug 03, 2009
  • 16 Answers
SOURCE: HOW DO FIX MY NUMARK TTX MOTOR?
if you know how to solder its most likely the toshiba chip under the heat sink, here is more in depth, i wrote this up about 3 to 4 years ago
Ciscoel Nino - "since numark fixed thier overheating problems by adding avent under the platter, i think that what is happeing is that our DCMOTOR DRIVER IC (Toshiba TA7259P) has gone bad what i am going to do itorder this, install it and let you know the deal. there only 5.80 apiece and shipping is like 8 dollars. ill get back to you. I amguessing it is sort of like computers CPU, like its got thermal gel/grease on it and all that fun stuff. It is on the Motor's board heres the image
(IMG:http://img97.imageshack.us/img97/9139/ttx19tl.jpg)
after i install it too, i am also going to cut vents like this under my platter like the updated versions
(IMG:http://img97.imageshack.us/img97/8523/ttxvents8pn.jpg)
also take your time when installing the chip.
1. its sensitive to static.
2.buy a low heat soldering iron.
3.do each solder point at a time, wait a few seconds for the IC to cool off. then approach the next.
also open your ttx and see what exact IC you need. Mine was a Toshiba TA7259P. Also when you order that, order small tube of thermal paste.
http://www.audiolabga.com/ for parts ordering"
Posted on Aug 30, 2009
satavlad
  • 405 Answers
SOURCE: my numark ttx deck has started being unable to
Fader has to be ether cleaned or replaced if cleaning did not work.
Posted on Nov 17, 2009
Epson me 101 reseter
Take out the cartridge. Dip acotton budinsurgical spirit(also known as rubbing alcohol), and rub all the yellow circles on the cartridge (the ones that make contact with pins in the printer). Once you've done that, grab a piece of tissue paper and dry the contacts with it.
Then, using the other end of the cotton bud, also dipped in surgical spirit, rub the print head (the gold square at the bottom of the cartridge) VERY GENTLY - you don't want to scratch it!
Reinstall the cartridge, maybe jiggle it a little bit in its place if you have to, and it should work. My iP1800 gives me a message when it thinks it's run out of ink, but I just press the "ignore" button and it prints just fine... I've never managed to successfully refill acolour cartridge(I refill the ink normally but it doesn't print), but my record so far is filling the same black cartridge five times over.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Office Equipment & Supplies
Remove paint from lcd screen
Try WD40 sprayed onto a cloth and then rub the white streak gently.
Oct 13, 2012 | Sens S1901DVD 19 LCD TVDVD Combo
Just replaced black cartridge and it's still not printing
Hi
I suggest to remove the cartridge and rub the print head into a plain paper with rubbing alcohol until ink flows. The print the print nozzle for 2 times. Then try to print again.
If not, dip it into a hot water for 5 minutes and then rub it again in a paper with rubbing alochol.
Run the print cleaning maintenance like print nozzle and then try to print again.
If not, you need to go to printing preferences and check the box GRAYSCALE in the print quality.
Please let me know if you need more help.
Mar 06, 2011 | Epson Stylus CX9400 Photo Printer
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
My wife inherited a '78 Ford Granada. It has the original silver paint. I tried to wax it, but it became obvious that it is heavily oxidized. I then tried rubbing compound, and after only a few circular...
Yes you will need to use a rubbing compound to have any chance of shifting all those years of residue.
There is a very good video walkthrough below on how to restore old faded and oxidised paint.
Please do leave a vote for the solution. Thanks.
Sep 22, 2010 | 1978 Ford Granada
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
The belt keeps going to one side+ rubbing,, is there anyone that
there should be adjustment screws on the rear roller.
only adjust one of them (usually the left) if the belt rubs on the left turn the screw clockwise 1/4 turn and if the belt rubs on the right turn counterclockwise. Make small adjustments until the belt stays in the center
Mar 24, 2010 | Proform 6.5q Treadmill Walking Belt
Peeling paint coming off of oil rubbed bronze basket strainer
Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
Mar 03, 2009 | Mountain Plumbing Mountain Basket Strainer...
Cdn36 pbm
Does it make this noise only while playing a disc? or is it when it opens and closes.
If it happens while playing a disc, it could be the spindle motor or something rubbing on the disc while it is spinning. Since nothing is supposed to be rubbing on the disc, it would need to be taken apart and looked at while it is spinning to see what that is.
Let me know if I can help you any more,
Good luck,
Dave
Jun 28, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
Numark TTX1 Turntable Logo
81 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
