Question about Fuji FinePix S5200 / S5600 Digital Camera
Preview option does not work.
I formatted the card and then took a picture.  It sounds like the picture is being taken, but I cannot see the pic in the print preview mode.  Please provide help to solve this problem.  It is a fuji finepix S5200 camera. Thanks
    President:
  • 1,223 Answers
U cant see it in lcd do u see anything on lcd is it totally blank then its a lcd failure but if it shows signs and functions then it might be a big problem coming ur way that is CCD failure , pls check ur pics by connecting are they normal without any white or pink shades then replace lcd screen
Posted on Feb 20, 2009
Just bought the Nikon S01 camera. Charged it completely, turned it on, completed setup, took a few pics. Then when I turned it off and back on, it says "Card is not formatted. Format card?" If I select...
Save the pictures you have taken to your computer, and then choose the Format Card option. You have to Format the Card to make your camera work. If this does not work, contact the Camera's company web site and ask them for advice
Sep 01, 2013 | Nikon Inc Nikon Coolpix S01 Silver
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
My camera locks after about three pictures are taken. It will not turn off or let you take another photo. When it ask if pics are ok it does not let you take another pic after you press the menu button...
have you formatted the memory card before usuing it? if the camera has the function, try formatting the memory card in the camera with its own option. if that doesn't work, try a different card. if it has its own internal memory, can you take more than 3 pictures, and if so, does it still freeze without using a card? it sounds as if the camera could be having problems writing the photos to the card. you could also try formatting the card on your pc and see if that helps. if you still have the same problem after these steps, it may be an internal problem with the cameras system and how it saves.
hope this helps
Apr 17, 2011 | Cameras
Can view pictures that i have already taken. only shows viedo
hit menu button will show u videos and also pics u took when u hit it few times then push button click it and arrows right and left to preview ,maybe u will have to take memory card off and then do what i said above might be the pictures on camera it self not on memory
Jan 28, 2010 | Vivitar ViviCam 3750 Digital Camera
Can't make any photo or preview
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Jan 04, 2009 | Olympus Camedia D-425 / C-170 Digital...
CAN'T EDIT OR MAKE ANY PICS
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect image and the card can be used again.
Olympus FE 230 -Not able to retrieve pictures, only format option
You may try some photo recovery software to rescue the files on your Olympus camera, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the memory card in case the original files(your pictures) are overwritten.
Dec 27, 2008 | Olympus FE-230 Digital Camera
Fuji FinePix E550
format by going to option while in shot pic mode , first press ok then option, set-up go down to format and after should be working.
Sep 05, 2008 | Fuji FinePix E550 Digital Camera
Preview mode not working and lines on the screen
canon ixus 500.
when i switch mode to playback/preview it doesnt work so i cant view pics that are taken or can i upload them to my pc.
Jun 28, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Retrieving file
There are companies that claim to be able to retrieve deleted files on mem cards, if their space has not been written over by other pics taken sense, or a mem card FORMAT. Google it.
Your better approach may be to try to recover the files showing 3Meg size on your computer download. Sounds like mem card quit working correctly after first 100 photoes. Was this a name brand SD card like San Disk or Panasonic? Beware of off brand junk sold on ebay or other sites CHEAP. They are designed to report back the size they claim to be, but are 1/2 size capacity or less in reality. You never know until you need your photos. The other thing is SD cards fail and are never a good as a BackUp source for files. For file xfers only in general.
Good lesson for all is to be sure all your pics show up on your computer before deleting on camera.
Jan 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
