Question about Acer Aspire M1201 Athlon X2 320 Gb PC Desktop
Aspire AM1201 does not boot up.
Was in sleep or hibernate mode overnight. Wife used computer in morning for a while. When she came back later, power switch light on steadily, but nothing comes on screen. Powered off, then on; even unplugged main power, but hard drive doesn't run. Tried my Acer default CDs for booting. No change.
  • mkdrees4 Feb 17, 2009
    Thanks for the response. Is there a way to get to BIOS if the computer won't show anything on screen?
    I do have an update on my problem, although I haven't actually learned anything. I turned it off with the Power switch, then unplugged the power cord for an hour or so. When I tried again, it tried to start, but got hung on the ACER page and did not start Windows (Vista, btw). I shut it down again and on the 2nd additional try, Windows started and seems to work fine. I turned off the power saving settings to try to avoid the problem in the short term.
  • 530 Answers
Hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Posted on Feb 17, 2009
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
How to get out of sleep mode?
You turned the laptop on and off and it still is asleep?
When you turned it off did the power go completely off? If not remove the power cord to make it go off.
Try booting up into safe mode and see if it goes to sleep.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity so you can view the manual later) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Check your Power Options in the Control Panel to set your Sleep Mode and Hibernation up higher or set it to NEVER. Click Start/Control Panel and look for Power Option (it might be under System and Performance).
Below is a link to your user manual. You want to go to Pages 77 and 78 where it talks about changing the Power Plan. You want to select Change Advanced Settings as it talks about on pages 78 and you will be allowed to change the hibernate and sleep settings.
http://support.gateway.com/s/Manuals/Desktops/8512158.pdf
Jun 03, 2012 | Gateway GT5692 Desktop Computer
How to wake msi u130 from sleeping?tnx
If it is in sleep pressing any key or moving the mouse will generally wake it up. If you left the computer unplugged in sleep mode then it most likely ran out of power. If your using hibernate I would recommend not using it as it has so many issues.... :) If you have to hit the power button to wake it up then it's either shutdown or in hibernate. FYI there will generally be an amber light on to indicate sleep mode. If no lights it's most likely not in sleep mode.
Comment if you need additional assistance.
Aug 24, 2011 | Acer Aspire One Netbook 8.9" Notebook
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
Acer Aspire ZG5 Power Led showing yellow
Hibernation is the biggest creator of software nightmares...it has killed more computer systems and corrupted more systems than I can count. Go to control panel > power options and change your power settings in there. Turn hibernation off and just have the computer go to sleep after a certain time. You will find that the computer will come right back in sleep mode and will be ready for action. Don't worry about the system running until sleeping and then waking up, it's a lot better than finding your entire operating system is now corrupt and has to be re-installed.
Sep 15, 2009 | Acer Aspire One PC Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Acer Aspire M1201 Athlon X2 320 Gb  PC Desktop Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
