Question about Bond Manufacturing Electric Patio Heater ?ƒ?¢?‚?€?‚?“ Table Top ?ƒ?¢?‚?€?‚?“ Bronze
Bond Manuf. Electric Patio Heater Item #65000
Purchased from Costco. Information sheet states there are three settings. Mine has two switches, one with just an option for lower heat and the next one has two lines on the switch which would lead me to believe you it it once for the two heater function and would put it up to the second level of the switch to turn on the 3 power levels. I am only getting the lower and one other level from the other switch.
I am pretty sure it does not heat up the 6' it states it should. THank you, Nancy
I need instructions to operate this remote. Thanks
as you gave us no information of make,model and what you want to control there is not much help we can give
Dec 09, 2015 | Televison & Video
BernzOmatich3200n
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
Ebay seller proble
The unit was purchased almost 4 years ago, so you have no claim against the seller.
The recall, or the reason it is unsafe is the fault of the manufacturer. Your claim is against them, and they should pay your freight charges for you to sent the item back to them.
And finally, this is the FIXYA website you are talking to, nothing to do with your sale at all and certainly nothing to do with Video Cameras, which is the category your posted to. FiXYA is a self help website, we are people just like you helping others because we can. We give information only and have no links to any account details or past transactions you may have had.
Oct 07, 2017 | Video Cameras
Patio heater goes out
If your patio heater goes out when you turn on the pilot and let go, this is usually a worn thermocouple. They last between 1 year (if you are unlucky) up to 6 years and are a consumable item. Found this site very useful patio heater problem solving.
May 24, 2012 | Dayva HS041 (LP) Open Flame Gas Patio...
When I let go the pilot button and the flame is on the minute I let go to turn it to max it die down each time!! what is wrong?
If you are running on butane try switching to propane, on cold nights butane will slow down and go out. If using propane then the first consumable item that fails on a patio heater is a Thermcouple, this will cause the pilot to go out if worn. Found this site very useful with lots of Patio Heater Problem pages.
Aug 16, 2011 | Endless Summer Round Table Top Patio...
I have a zeus patio heater. the right side element wont come on, but when i put the element in the left side it is fine. Can anyone help?
The burner is either clogged or rusted out on the side that doesn't come ON. You will need to replace the entire burner though, to solve the problem.
Hope this helped you.
Apr 25, 2011 | Superb PHP40 Patio Heater
I have a Fire Sense Patio heater, it worked for awhile and no it will not light. You hold done the button it ignites and as soon as you let go of the button it goes out.. It is not the propane tank, we...
sounds like the regulator is vapor locked. turn everything off, tank, any switches on unit itself, any valves.everything. now disconnect the gas tank. let sit in the sun for a bit, so we cant get you going quicker. start at to tank, reconnect that. now follow the manufactures specs for operation.
Mar 15, 2011 | Fire Sense 02411 Standard Patio Heater...
Heater stopped working, is there a reset button?
Have you tried to replace the bulb, it is about a $100 item. I replaced mine and it worked again, just follow the manual for instructions too about 20 minutes.
Dec 25, 2010 | Fire Sense 02109 Patio Heater
Bond Manufacturing Electric Patio Heater ?ƒ?¢?‚?€?‚?“ Table Top ?ƒ?¢?‚?€?‚?“ Bronze Logo
116 people viewed this question
Top Bond Manufacturing Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Bond Manufacturing Pool and Spa Expert? Answer questions, earn points and help others
