Posted on Feb 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting a phase linear 700a power amp to 4000 phase pre amp
Wiring these two together
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Feb 17, 2009
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1563656
Points
12312
Unfortunately, the title of this question has been truncated, so I can't tell what you are trying to connect. Can you update this and describe what you are attempting please? I'll direct you from there.
Thanks,
Dan
Phase linear model UPA424 wire diagram
YOU WILL NEED A SOLID WIRE FROM UR DECK TO UR AMP 4 A REMOTE WIRE AND A GOOD SET OF RCA JACKS
Extreme distortion/static in music.
you might have blown your speakers. Thats what it sounds like, if it got loud with a lot of low-end then it got all staticy and distorted, you fried teh speakers.
My phase linear uv7ts wont come on at all
check your ground connection and all wires for loose connections.
match wires according to color.
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Pre amp to amp
Pre-amps don't put out 750 watts. They put out about 1 volt at several thousandths of a watt. I think you are calling a 750 watt amplifier a pre-amp, and that ****** will definitely fry things.
Pre Amp Set up
Get the right cables and plug them in. Pre-amp to mixer to amp. Radio Shack is a good place to buy the wires with proper ends on them.
3helpful
4answers
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Amp
It should have a blue wire from the harness on the back of the player for turning on the amp, it may also be labeled "antenna" or "power antenna" or "P con". That is the one to run to the remote turn on of the amp.
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
