Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso washer leaves clumps of lint on clothes
We have had this washer for about 6 years, and I have never been all that happy with it. However, in the past year it has gotten worse. It runs fine, but it leaves these gross clumps of lint on my clothes. It is most noticeable on darks and whites, but is present on pretty much everything. I have cleaned every possible nook and cranny of lint and gunk to no avail. I am about ready to ditch it and get a front loading HE machine that works. Any ideas on what I can do before giving up?
  • 130 Answers
Sorry to hear you got one of these. they stopped making that model because of multiple problems. I have seen the lint issue come up with these over and over w/o a solution. I can say if you are not using a dryer to dry getting one will help.
Posted on Feb 16, 2009
  • Chad Light Feb 16, 2009
    sorry to hear you got one of these. they stopped making that model because of multiple problems. I have seen the lint issue come up with these over and over w/o a solution. I can say if you are not using a dryer to dry getting one will help.
Our Whirlpool Calypso model #GVW9959KL washing machine has started leaving light colored marks (kind of look like lint, but won't brush off like lint might) on dark clothes. Do you know of a way to...
sounds like you might have mold inbtween the tubs and its starting to wash loose and get on your clothes. try a washer cleaner like washer magic and see if that helps.
Feb 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso machine leave alot of lint on clothing
you have to clean the lint trap before every use. I assume that you know that. also , you need to clean the area where the lint trap is really good, so you dont have a dryer fire.
Aug 25, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
How to remove the cap on Kenmore Elite Calypso washer
you'll need to access the pump and remove the hoses. Clean the inlet screen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Feb 20, 2009 | Kenmore Elite 21086
Kenmore Elite Calypso won't drain
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
240 people viewed this question
Dan Webster
Dan Webster
Sal De
