Question about Whirlpool LER3622HQ Electric Portable Dryer
Whirlpool dryer has very little heat
The Whirlpool dryer is only 2 years new and starting last weekend it takes forever to dry because there is only a little heat coming from the dryer even with the settings to high. I checked all wirings, fuses, fans, and gas lines where all are working properly. There is heat but very little. How should I fix the problem?
  • 150 Answers
Sounds like your not getting enough gas supply,there is a regulater that controls the flow of gas they can get carbon build-up and restrict the gas.You need to turn off your gas supply and unplug it,remove the regulator and clean the lines,or replace the part.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 17, 2009
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
My dryer takes forever to dry anything and often times will not turn on when i press start after it's been ran for a 70 minute cycle but will turn itself on after sitting for awhile my dryer is
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 14, 2012 | Whirlpool Dryers
Dryer takes 2 or 3 cycles to dry
A Whirlpool dryer either heats or doesn't heat . This problem is an indication of a blocked vent hose , from the rear of the dryer to the outside vent outlet . Try removing the vent hose from the back of the dryer and dry a load , to verify this problem . Wet lint inside the hose also means the air cannot escape to the outside .
Apr 18, 2010 | Whirlpool LER4634J Electric Dryer
My Whirlpool dryer is taking forever to dry a load of clothes. Sometimes it works and some times it doesnt. How do I fix this?
when did you last clean out the dryer?another thing is that the gas coils could be failing,they work for a while but when the heat up they cut out leaving clothes damp or partially dry.there should be a little peep hole on front of dryer to see flame inside,pop off the cover after 10 or 15 minutes and make sure the flame is still coming on,if there isn't a cover you'll have to remove the bottom panel to check this,if the coils are good clean out the dryer by vacuuming the inside of it,remove the duct that the lint filter slides into and clean that out,then go outside and make sure the air is blowing out strong enough to open the flapper all the way,if it isn't the block is inside the vent line,remove the line from the back of dryer and clean it,if it's along run from the wall to the outside blow it out with a leaf blower and that should take care of your problem,you should do this a t least once a year so you don't have a fire on your hands,so clean out the dryer and make sure you don't have bad gas coils
Oct 17, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer has heat..but very low temp , takes forever
Make sure that your vent pipe is completely clear of excess lent. It will not dry properly if the venting is not running freely. If the unit is cleared of lent, inside and out, the only other possibility is the thermostat is not reading correctly.
Apr 11, 2009 | Dryers
Inside of the dryer is cracking- huge holes!
the drum can be replaced but dont know if you want to pay for one they are probably expensive and 2nd if it is taking 2 to 3 times to dry clothes you have a vent problem which has caused the cracking of the drum probably cause so much heat build up in the machine your vent is stopped up and it isnt keeping the heat and moisture in the dryer which is a fire hazard please call a technician and please rate this
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Heat and clean vent, but way too long to dry
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Whirlpool LER3622HQ Electric Portable Dryer Logo
176 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
