Question about Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Put in new water filter
I changed the water filter, however the red light on the outside of the refrigerator won't go out. Thank you
I had to same problem, I had to press and hold the lock and the light button for 3 or 4 seconds. Then it went off!!
Posted on May 07, 2009
  • 10,865 Answers
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Posted on Feb 16, 2009
  • Joe Hogan Feb 16, 2009
    To Reset Indicator:
    successfully reset.
I have water pressure at the filter but none at the dispensor or ice maker?
Posted on Jul 06, 2010
SRS580DW Water filter indicator red light is on. Where in the fridge do I find it to take it out to replace pleace?
Resetting the water filter indicator light can also be found in the user manual for your SRS580DW Refrigerator User Manual page 8 The water filter indicator initially lights up green. Press the ICE TIMER and ICE MODE buttons at the same time for about three seconds to reset the water filter installation date. • The green light changes to orange after five months to indicate that you should soon change the water filter. It changes to red after an additional one month (six months after the water filter was changed or installed) to indicate that you must change the water filter. • If you wish to turn off the filter indicator lamp or the filter is not connected, press the ice timer & ice mode button simultaneously for 5 seconds. If you wish to turn on the filter indicator lamp again, press the ice timer & ice mode button simultaneously for 3 seconds. Click Here for the SRS580DW User Manual I am here should you have questions Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I changed the water filter and I can't change the red indicator light to green on the outside of the refrig. Help!!! Maytag side by side
AFTER CHANGING THE FILTER . YOU THEN HAVE TO HOLD DOWN THE LIGHT BUTTON AND THE LOCK BUTTON AT SAME TIME FOR APPROX 3 SECONDS AND THE FILTER LIGHT WILL FLASH THEN GO OUT
Dec 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
successfully reset.
Thanks, Sea Breeze
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
Change filter light
Light (select models)
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
How do you reset the change filter light , have replaced filter
Question:
I have replaced filter but how do you reset change filter light?
Have replaced the filter. The light is still red. Answer: After changing the water filter, press Cubed and Crushed buttons simultaneously and hold 3 seconds.
Jan 28, 2009 | Samsung RM255LASH Side by Side...
Water filter alarm light
without the specifc model number i beleive you hold down the button under the filter light to clear it i think its a hidden button right under the light but if not send me the model num and ill look it up
Jan 09, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
290 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
