Question about Danby DDR586R Dehumidifier
No power I have a ddr586r have had less then a year, and all of a sudden we can't get any power to it, tried in a couple of different plugs and still won't work, work great before. Lost
  • vanessadyken Feb 16, 2009
    plugged in the unit,and i still don't get any power to it whatsoever. anyother ideas? thanks
  • 10,865 Answers
Factory Default Setting:
When the unit is first connected to a power supply, the
electronic circuit board will automatically default to the
following factory settings;
Mode: Dehumidifier
Humidity Set Air Value:60% RH
Fan Speed: = Low
NOTE: In the event of a power failure or the unit is
switched ‘Off’, the most recent settings are retained and
restored once the power is switched “On”/resumed.
IMPORTANT NOTE: Depending on the ambient humidity
conditions, when power is restored or switched ‘On’ the
dehumidifier may not start automatically under the factory
or custom (see page 7) default setting. This is an indication
that the ambient RH% level of the surrounding environment
is lower than the current default setting and it
may be necessary to select a lower set RH% value.
Posted on Feb 16, 2009
  • Joe Hogan Feb 16, 2009
    Mode: Dehumidifier
    Fan Speed: = Low
    IMPORTANT NOTE:
Hello i have a dehumidifier Danby DDR586R water runs out of the bottom of unit
is the condensate resovoir in place correctly or full? take it out and put it back in.
May 10, 2012 | Danby Dehumidifiers
Hello, I have a Danby DDR586R dehumidifier. Please help me troubleshoot the problem that it is not working. I turn it on and have selected different modes but there is no water going into it. Thank...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 08, 2011 | Danby DDR586R Dehumidifier
I have a danby ddr586r dehumidifier. the coils are icing up. the outside of the unit also has ice build-up on the left hand side.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 30, 2011 | Danby DDR586R Dehumidifier
Lost owners manual ...looking for 1 online to download..model #DDR586R
Your model may have been discontinued, as it doesn't show up on any list I have. However, you can call Danby Customer Service 800-263-2629 and they can provide one for you.
Mar 11, 2011 | Danby DDR586R Dehumidifier - 58 Pints...
Why is the air coming out is cold
Because a dehumidifier is actually a air conditioner that runs very 'poorly' The way to get the water out of the air is to have a difference in temperatures ... remember in the 4th grade science class when the teacher talked about the DEW point? That natural law applies here.
Secondly, air i motion generally feels cooler than air not in motion. It is one of Newtons laws (I think)
Thanks for visiting today.
Jan 04, 2011 | Danby DDR586R Dehumidifier
Stays on fan and wont switch to the water symbol
Did you just empty the container? We have one that sometimes you have to slam it back in to get the red light off. Try to take it out and put it back in. Power it off even if you have to unplug it.
Hi I have Danby Dehumidifier about 2 year prolem is Compressor and fan running but no water and heater
heatman101
Nov 27, 2010 | Danby DDR586R Dehumidifier
It blows cold air while in heat mode
I have the same problem, I have a defect in the heater electric circuit, 2 small electronic things that looked like small pens with red end, no idea yet what they do, are located directly onto the heater element are faulty, I bypassed them to test the heater and it worked, either one or both requires replacement, tomorrow I,ll go to adisson buying the 2 for 99 cents each, re-weld the circuit and bang, ready to run for another couple of years
Feb 15, 2010 | Danby DDR586R Dehumidifier
Bucket fills instead of going down the drain
You may have an unintentional trap in the line (an up and down up and down. Hose has to lay flat on floor to drain.
Jul 04, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Danby DDR586R Dehumidifier Logo
258 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
Colin Stickland
Colin Stickland
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
