Question about GE Refrigerators
Compressor mounts? GE TBX21DAXPRWW refer compressor clunks when cycles off, like it is hitting the side of fridge, comp grommets worn or clips or both?Have not taken apart yet, but sound tells me a repair is in order soon
  • Bryan Feb 16, 2009
    Should I replace the spring or are you saying do nothing leave alone? :-) Thanks
  • 121 Answers
No problem with this it can work for a years,spring on compressor is
weaken and it is only unpleasant sound.
Posted on Feb 16, 2009
The compressor makes a big clunk clunk sound when it shuts off
The compressor motor mount is broken and that allows the compressor to flop around and clunk when shutting down.
That also allows it to twist and turn as it starts...
this will have to be fixed before the refrigerant piping breaks...
heatman101
Oct 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have Westinghouse apartment size fridges - some of them are making a very audible knocking sound when the compressers turns off. This does not happen in all the suites - we have 36 fridges. Thanks for...
Hi. Thisis a really simple fix. The compressor grommets are worn just from normal use. The compressor torques during start and hammers the compressor base against the mount. Then when the unit shuts off it generates a reverse torque and the base moves hammering the grommet against the mount.
The grommets are changed by usually remvong the mouting pin clips lifting the compressor ONE foot / grommet change at a time and then slide the locking pins back in place.
Have someone look at the grommets or get 1 compressor number and then go to any appliance parts source and either order or purchase your needed grommets.
It is not an expensive fix and they could all be done in less than1 day if someone was diligent. The biggest time consumer here is the process of opening the lower back panel. I would however plan on de-linting / cleaning with a vacuum and brush EACH units condensor coils and fan (if installed.)
Again remove ONE grommet (example) order replacements locally at the appliance parts source and install them.
Kelly
Sep 20, 2010 | Westinghouse Refrigerators
We have a GE TFX22PRXA AA side by side fridge/ freezer . When the compressor shuts off we hear a loud clunk/ rattle. Is there a problem with the compressor, or might it pssibly be a bad mount on the...
The rubber feet mounts are probably shot, if you cannot replace them do not worry, The motor and winding are suspended on springs inside the pot, they may be just weak. it should not cause any damage.
May 17, 2010 | Refrigerators
Clunking noises when cycling off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Jan 05, 2010 | Refrigerators
Frig shutters and makes noise when the cooling cycle shutoff.
It is probably caused from one or more of the four rubber bushings that mount your compressor to the refrigerator frame. The bushings wear over time and causing the compressor bracket to have a little play. Then when the compressor stops it moves the frame slightly bumping against the mounting bolt causing a slight to moderate sounding clunk when stopping, Also check a lines and cords as a cord refrigeration line near the compressor or fram can also cause the problem.
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Clunking noise every 5 seconds
You should check the compressor compartment and see if the fan motor (if it has one) is hitting something. Possibly a dead mouse?( I have seen this before) Also check if compressor mounts are secure. Hope this helps.
Jul 28, 2009 | GE Profile PSI23NCR Side by Side...
Kenmore fridge, about 8 years old, making noise
The compressor on your fridge is mounted on rubber grametts and inside the dome the internal parts the do the pumping of the refrigerant are mounted on springs. When a compressor gets old some people complain about two much vibrating, this could be the rubber grommets the support the compressor. When one of the support springs inside the compressor is broken it will have a distinct rapping sound when the compressor shuts off. There isn`t anything you can do about this, short of replacing the compressor. It will eventually get worse untill something is seriously broken inside the compressor and the compressor will die. You may want to consider replacing the compressor now or purchase a new fridge. You will need to consider the cost of both and the age of the fridge" Is it worth repairing?". You can actualy find a repair company in your area from this site if you like, and compare the costs.I hope I have helped explained the problem well enough for you. I will help you as much as I can.
Nov 15, 2008 | Refrigerators
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Beko fridge freezer humming
- Loose flooring or floor not firm.
- Check the body of your unit is not touching the wall or other object.
Jan 12, 2008 | Haier (492420265334) Refrigerator With Ice...
Side by side stopped working but clicling noises every second two.
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Feb 11, 2007 | GE GSH25KGRWW Side by Side Refrigerator
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
