Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Cold water coming out slow - maybe filter?
Had plumbing issues and think it is a clogged filter - where is this filter located and what part is it so I can replace it
  • joymorales Feb 19, 2009
    Thanks!!!!! Great
  • 130 Answers
Take off your watr hoses and check each end for sediment. If they are not clogged you need to repalce the water inlet valve that the hoses connect to.
Posted on Feb 16, 2009
All of my Plumbing in the house has good pressure with the exception of my kitchen why
Faulty valve maybe. Depending on your location, maybe frozen lines.
Nov 04, 2017 | Plumbing
Water has stop flowing out frige when push button. was slow at frist
Their are 3 possibilities
1) if your model is equipped with a filter it is clogged and should be replaced
2) the resevior that chills the water before dispensing it is frozen,it is located in the bottom of the fresh food(ref.) compartment behind the crisper drawers
3) the water inlet valve in the rear of the ref. where the house plumbing attachs to is defective
Jul 25, 2011 | Refrigerators
I installed a dhc tankless heater, but when I open only the hot water everything is ok, but when I open the cold water at the same time the heater turns off.
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Stiebel Eltron DHC-E 8 Tankless Electric...
Do the profile washers have a inlet filter for cold water.Hot water comes in fine.Cold very slow
check the cold water hose the screen in the hose to the cold water,selenoid may be clogged or have hard water deposets,just clean out see if this helps
Jul 03, 2010 | GE Profile WPRE6100G Top Load Washer
Is there a cold water filter on this machine. The
there is often a screen located in the hose end ... you can clean, replace or remove the screen and always replace the hose washers but its far better to replace both hoses with good quality new ones .. the safe lifetime of the hoses is only a few years ... so its a good idea to replace them every few years anyhow ... while you have the hoses off you can check water flow to make sure the shut off valves are not clogged .. (make sure they were both fully "on" to start with) .. if there is good water flow and the screens are not clogged then you may have a clogged solonoid valve (just inside the machine at the water inlets) (has wires going to it also)
Oct 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 series Clothes washer
there are filters in the fill hose which could be blocked but usually the fault is low water pressure
Aug 31, 2008 | Kenmore 24032\24036 Top Load Washer
Water Despenser
Water inlet valve at back of unit may be partially clogged, no repairs on this part, unless it comes apart and has a stainless steel wire mesh strainer that can be cleaned ( not likely), only replacement. BpB
Aug 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
