Question about Casio QT 6000 Point of Sale Terminal
Kitchen printer won't print
Casio TE 2400 says printer is offline (E060) but the printer works on my other TE 2400
do i have the settings on the till set up wrong?
  • 530 Answers
Hi im josh in cebu phils. friend the problem is in your setting try to change the port being used. go to settings the printer config..the printer port usb, local, com. then number if it is in 1 2 3 or so on. choose default if you used the default one. good luck
Posted on Feb 17, 2009
My Casio TE-2400 is showing =w/ when in REG mode and in PGM mode, doesn't show the number of the program I want to access. Any ideas please?
Someone has been fiddling with function key names. Do a program print out of PGM2 mode and find which name has been changed to =w/ in the list. Program it back to original.
Jan 05, 2017 | Casio TE-2400 Cash Register
Why won't my se-s700 print with ink? Feed key works, everything else still works, just seems like I'm out of ink?
That machine does not use ink from the till.It only works with a thermal paper that comes with inbuilt ink. Just make sure you are using the right paper and insert it properly , it only prints on one side
Jun 05, 2014 | Casio TE-2400 Electronic Cash Register
Casio te 2400 cash tender will not work, pre
Try programming 8 zero's into the cash key in program 3 and program 1.
Aug 19, 2013 | Casio TE-2400 Cash Register
Casio TE-2400 is subtracting 2 pence when I ring through and item and press subtotal- how do I sort this?
It usually means someone has made a mistake while changing prices.
try this:
turn key to program mode
press 0 button
press CASH button
press SUBTOTAL
If anyone has trouble programming the Casio TE-2400 cash register, the programming manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Sep 08, 2012 | Casio Parts Cash Register PC Desktop
Casio te8500 kitchen printer
Unfortunately, the ports can be configured for any of the supported devices so there are many settings that have to be matched. You also need to have a cable wired to casio specs. Any old cable will not do. Then you configure printer routing settings and PLU settings. It is best to get a dealer to configure everything for you in this case. If you are keen to try yourself, you will need the dealer manual for the setting tables. There is one here:
http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/TE-7000S%20and%20TE-8000F%20and%20TE-8500F%20programming.TOC.pdf
Jul 29, 2012 | Casio Parts Cash Register PC Desktop
Morning, I have a Casio TE-2400 Cash Register.\r\nThe till roll feeder unit rollers are worn and need replacing. When you register a sale the till roll feeds out but the printing is bunched up and in...
I have been dealing with the 2400 since it was released and I have NEVER seen worn feed rollers. They are a VERY reliable printer. I would check a few other things first. Make sure the paper is 57mm wide. Wrong width is common and it will cause many different problems. Try pulling a little paper off of the roll and just print on that. The roll can sometimes be too tight or heavy to pull through the printer and this will show you if the problem lies here. Also, does the problem happen on both the receipt side and journal side? The only other thing I can think of is maybe a damaged drive gear (or dirt stuck in the gears) but this should only affect one of the printers.
Jul 14, 2011 | Casio Parts Cash Register PC Desktop
HOW DO I CHANG PRICES ON MY TILL CASIO TE 2400
Turn key to Program Type the new price (NO DECIMAL POINT) Press the item button that you want to save it to Press SUBTOTAL
If anyone is looking for a Casio TE-2200 / TE-2400 manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Many more available at http://the-checkout-tech.com
Mar 24, 2010 | Casio Parts Cash Register PC Desktop
Casio QT 6000 Point of Sale Terminal Logo
248 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
