Back to:
Tags:
Logitech Wingman
Logitech wingman problem
By Phoebe - usenet poster
Does it have a settings for seperate axis on the pedals?
The answer to this one is probably dead simple but...
I bought a wingman formula gp wheel today to try in GPL. Brought it home, set it up as per instructions (I guess) and went to Monza to test. First shot the Lesmos the car wouldn't stop. Well, it finally did when it hit the fence, but that's not the preferred method, is it? No brakes when my foot is on the throttle. uh-oh! When calibrating in GPL with my advantage pedals (in generic) I would get an axis for the steering, an axis for the throttle and a third axis for the brake calibration. When calibrating the wingman in gpl I get an axis for the steering and only one other axis for calibrting both throttle and brake. Don't seem right. Can't trail-brake. Where am I going wrong?
buzz
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Cornish
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I got the same problem. I got the old Logitech Wingman formula force and if I don't report the pedals I get no respons from GPL. It sucks to not be able to brake and gas at the same time.
/Blackhawk
buzz
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on logitech wingman problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Putty
Rating: 0%, 0 votes
first do the basics..make sure your wheel is the way you want it in the
windows control panel. Also make sure it is using the #1 slot for
controllers. (if you have more than one controller hooked up...disable them
for now)
In the game there are two methods available to sample the
joystick..DirectX and the Papyrus optimized driver. Make sure your using
the DirectX input. There is a checkbox in the options screens
good luck
dave henrie
going wrong?
buzz
Thank You!
Solution #3
Not Rated (0)
Beresford
Rating: 0%, 0 votes
well if its like my formula force there is a setting under specail options (or something like that) for report combined pedals. this is checked by default. Uncheck it and you should be all set.
MadDAWG
Thank You!
Solution #4
Not Rated (0)
maartenw
Rating: 0%, 0 votes
Was about to walk you through the settings for the FF-models (which have
combined axis set as standard) when I realised yours is a standard gameport
one. So I downloaded the manual from the Logitech site and found there
doesn't seem to be an option to seperate gas and brake as there is with the
FF models. I.e. you were sold a dud.
So, IMO, you're left with two options:
1) take it back and exchange for a model that has a seperate axis option.
2) re-wire the unit.
BTW: I would recommend taking your foot off the accellerator at some point
when braking for the Lesmo's, otherwise you're going to get outbraked a lot.
Jan.
"Pay attention when I'm talking to you boy!" -Foghorn Leghorn.
Thank You!
Can you Help with these PC Gaming Devices problems?
PC Gaming Devices
It is an older version.We are apparently missing whatever...
PC Gaming Devices
When I enter a key command or mouse movement or button...
PC Gaming Devices
can you please write c++ program that will accept 10...
PC Gaming Devices
how do i get the instruction manual for a pelican ps2...
Loading problems.
Repair Service
Find PC Gaming Device Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
