Question about Whirlpool LEW0050PQ 3.8 Cu. Ft. Electric Dryer - White
Dryer not powering on
The dryer door switch was fried (one of the connectors was black and the switch was partially melted at that connection). I replaced the switch and it worked fine for a couple of days. Now it won't even power on, and the door switch is fried again. Any ideas on what I should try replacing next (besides the door switch)?
  • 979 Answers
The second frying of the switch indicates a major problem somewhere. Start at the receptacle and work your way back to the inside of the dryer and see that everything is tight. I think you will find that the problem lies at where the wire ends at the block inside of the back of the dryer. This might be ugly. Dryers conduct a lot of heat and electricity and can be safe if wired properly. Your breaker may need to be reset. Turn it off and then back on to get it to start up.
Posted on Feb 22, 2013
4 Suggested Answers
SOURCE:
heatman101
  • 43501 Answers
SOURCE: Whirlpool WED5800S electric dryer - wont start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 12, 2010
  • 59 Answers
SOURCE: My Whirlpool Dryer GEW9868KQS has power, but
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Posted on Oct 18, 2011
SOURCE: Admiral Dryer will not heat
fixya is worthlessya!
Posted on Oct 25, 2011
Rear wiper does not work
Bud I would suspect you may have melted wires farther up on the ones coming from the switch to to the rear of the car. Should have that checked cause it will be a fire issue. Your motor should have never melted before the fuse blew.
Aug 02, 2018 | Dodge Cars & Trucks
Why did the latch switch J61424tooap connector melted, could it be because of 3spots of bare metal on door frame?
It is most likely due to the connection becoming loose. A poor connection will cause the heat and melt it. You can replace the connection and it should fix the problem.
Jun 02, 2014 | Panasonic NN-T993SF Microwave Oven
Need to replace wiring harness on LG dryer DLE7177RM model. How can I connect the wires that extend inside behind drum?
Dryers are very easy to repair.
Video on how an electric dryer works: http://youtu.be/2xUKBtLkaeo
Video on how a gas dryer works: http://youtu.be/mcipN8bvpa0
Best regards ~
Mar 16, 2014 | LG DLE7177 Dryer
Electric dryer will not start
If the filter chute or vent to outside is clogged the skinny white fuse mounted on the blower next the the control t-stat melts. This kills power to the door switch circuit. The door switch circuit stops the motor whenever the door is opened using a door switch. If the door switch lever is broken or the door switch is broken she won't rune either. Now here is my home movie and whirlpool dryer page:
DAN'S DRYER REPAIR PAGE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 28, 2013 | Whirlpool Dryers
I am trying to replace my samsung J845 door interlock switch but have lost my wiring diagram. Can anyone tell me what colour wire to what pin?
I found this pic on Google images. Hope this helps. I was having the same problem as the whole door lock and the wiring connectors were all melted because of a short. Samsung washer door interlock mechanism and wiring connections.
Jul 19, 2012 | Cars & Trucks
Still turns after opening door
When the door is closed the switch will close, allowing power to circulate through the rest of the circuit. When the dryer door is open the switch will open, breaking electrical contact to the neutral connection of the circuit and stopping the flow of electricity. so it sounds like a bad dryer door switch.
Feb 02, 2012 | Frigidaire Dryers
I have a GE Dryer model DBVH512EF0WW. I recently replaced the drum support bearing and the air duct assembly. But with everything plugged back in, the dryer will not power on. Checked voltage to and from...
If there's absolutely no motor hum when switched on there's just a chance the front door interlock switch isn't re-connected properly - could have been stressed when working on the drum. Check the connector and check for voltage being activated when door closed.
Good luck.
Nov 23, 2017 | Dryers
Headlights not working
many times the switch goes bad or the connection to the switch burns up only to the headlamps(check for melted plastic and burnt copper between the light switch and the light switch connector. While your there replace switch and connector if it looks fried.
May 24, 2010 | 2004 Dodge Caravan
Sparks from starter switch wires
you may have lost one leg of power at the panel if fused or on 2 single pole breakers,or you could have burnt the neutral connection somewhere inside the unit
Jul 18, 2009 | Dryers
Whirlpool LEW0050PQ 3.8 Cu. Ft. Electric Dryer - White Logo
114 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
