Question about Kenmore Vacuums
Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
My Kenmore canister vacuum is about 6 years old. Today when I was using it, smoke suddenly started coming out from the canister motor area. The motor was also making a funny, dying sound. We unplugged it and let it sit an hour, but the same problem persists. We've changed the bag and filters and made sure that there are no blockages.
The vacuum has never been serviced before. I am wondering if it is worth looking into getting it repaired or is it better to replace it.
(Kenmore canister Vacuum: Model 22550300C)
  • 31 Answers
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Posted on Feb 16, 2009
It's 5 years old and I vacuum twice a week about 900 sq ft. It is starting to smoke and the belt sounds like it's working overtime. The hose is fine. The bag is continuing to fill up. The floor...
Make sure that the dirt bag is empty and that the motor bearings are good. Also check for any debris that may be gumming up motor bearings and forcing it to run slow.
You also can check out the motor brushes and replace them.
Mar 22, 2017 | Kenmore 25512/ 25513 Progressive Canister...
The beater bar on my Kenmore Progressive stopped turning. I tried to clean the hair out of it, then switched it back on. The bar still wasn't turning and then it started to smoke..... lots of smoke,...
The belt is broken.First while looking at the brushes,find the screws that hold that bottom plate on.Remove the screws and the plate comes off.This will allow you to lift the brush out of the vacuum.It is important to make note of how the brush fits in the vacuum.The new belt will fit on a groove on the brush.The other end fits on a small wheel about six inches back from the brush.
Thank you for using Fix Ya.
Jun 03, 2011 | Kenmore 27514 Bagged Canister Vacuum
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Kenmore progressive canister bad connection from hose to canister
It could be, the female part of the connector is stretched open. You can usually insert something, like a dart, between the sleeve and the holder, to tighten it. If you paid with Pay Pal, see about getting your money back.
Jul 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Problem with motor; need to open the motor compartment
The top piece near the back comes off, use a screw driver to pry the corners out then it will come off. Then you can get to the 2 screws holding the motor housing off. When you put it back on, it just snaps in place.
Oct 24, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
475 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
