Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mitsubishi Mr slim Airconditioner error check P8
Have a Mitsubishi Mr Slim Cassette unit PUH-3YK has error message on keypad CHECK P8 can someone shed some light on what fault this message applies to
  • 1 more comment
  • amperaservic Feb 18, 2009
    It is running in cooling mode & have discovered that the compressor is siezed hence the abnormal pipe temperature fault thanks for help have ordered replacement compressor
  • ferasss Mar 06, 2009
    Hi;
    I have the same problem ,but when i start the AC its cooling for a few moments and then the error comes ..
  • luke bussenschutt May 11, 2010
    p8 = abnormality of pipe tempreature, when the problem occurs is it running on heating or cooling?
I Have same problem
Posted on Sep 28, 2009
  • 3 Answers
I have the same problem with one of my installation building...out of 60 units i encountered 2 of them and thyis morning we check all of it. we dismantle also the evaporator and check it for any dirt on the filters all woring fine until i run it on and when it beginning to cool then i comes out the error and got an over charge reading on the gauge....
Posted on Dec 08, 2009
Error p8 is coming in the remot unit on after 3 mintus
error p8 is coming in the remot unit after 3 mintus
Dec 26, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
It is a ducted Airconditioner When started after few minutes it stops and a control panel indicates: check P08 with kind regards annurag anurag@maluxme.com
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor.
Check may be icing in your indoor coil due to evaporator coil /air filter blocked- Clean it.
Short of gas or gas leak. Call repairman to find out the leak & arrest to recharge gas.
Helpful?
Dec 25, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim PK 18 FK 3 will only cool for 3 minutes, then goes to fan only for 3 minutes, then shuts off completely with P8 00 flashing as an error message
P8 usually is caused by a low charge...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 30, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi mr. slim showing P8 on thermostat
p8 means problem at out door unit google mr. slim p8 fult code describes in more detail
Jan 15, 2010 | Humidifiers
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
No heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Nov 13, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
5,021 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
