Question about GE Washing Machines
Washer stopped aggitating and spinning
The washesr stopped spinning out and aggitating. I figured i needed to pop the top and have a look, but i cann't get the top open. How do I do this? it's a ge washer.
It was the motor coupler. I replaced that and all is good.
Posted on Feb 17, 2009
Roper washer rax7245awo won't spin/aggitate
is this a top loader??there are clips on the edges of the top..they require use of a regular screw driver(flat blade) inserted between the top and sides..them it should pry up and tilt to the back..on hinges..
Feb 02, 2014 | Roper Washing Machines
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
The washing machine doesnt aggitate
the first thing to check is your lid switch.
does the unit drain or spin?
you may need to check your drain pump to see if anything is stopping it.
you should also check the wiring from the motor to the timer.
Mar 25, 2010 | GE WBSR3140DW Top Load Washer
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Will not spin and then when I try to start the cycle over all it will do is aggitate. It is also overfilling and spilling onto the floor. It is a top loading GE washer and is just over a year old.
sounds like the water level switch is not working pop the front cover off and see if the tube on the left of the tub is still hooked up. to remove front cover use a putty knife and slide between thee top and the front cover you wil feel the knife stop about two inces from each side push in on the place where it stopped and pull out on the front cover
Dec 05, 2008 | GE WBSE2090A Top Load Washer
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
