Homemade PC beeping constantly
I built a computer out of an Intel SE440BX-2 motherboard that I picked up at a garage sale. I put it together using parts I had around my house, and installed Windows ME on it. I found an old, generic PS/2 mouse and a Gateway Anykey programmable keyboard from an older computer and used them.
It worked fine for a while, and now every time I use that keyboard, the computer starts up, but the keyboard won't initialize and doesn't respond when I press any of its keys. On top of that, whenever I move the mouse, it emits a steady stream of short beeps. Sometimes it'll open about twenty windows explorer windows, too. It's really weird. I think I've heard that computers will do that when there's a stuck key on the keyboard, but the keyboard's fine. Although, one key does seem to have had something spilled into it. Any ideas as to what the problem is?
  • 3 more comments
  • rusbus Feb 16, 2009
    I've already seen that website, and I still don't know what's wrong. It's just not enough info. Thanks a lot, though! I appreciate it!
    Oh, it's not only in the BIOS that it beeps. It also does that once I've entered Windows.
  • rusbus Feb 17, 2009
    Oh, I have tried other keyboards, and they work, but I really like that one a lot. And it's the only one I don't have to steal from another computer.
    That's a problem, because this keyboard is nearly impossible to disassemble completely. I can't access the spot beneath the key I'm worried about. There's a big cover over the keys that has little heat staked tabs on the bottom of the keyboard. The only way I can figure to open it would be to drill those out, but then I'm afraid I wouldn't be able to assemble it again.
    Come to think of it, I forgot to mention that the keyboard works fine on its original computer. It just doesn't work on my homemade one.
    President:
  • 2,692 Answers
  • Thomas F. Schneider Feb 17, 2009
    You have tried another keyboard?
    Seems you alread know the problem is in the keyboard,and most likely the key that you seem to say sticks. Remove the key, clean under it with a cotton swab and isopropyl alcohol while holding the keyboard upside down.
I want to upgrade the cpu on a se440bx-2 slot 1 PIII motherboard
If you go to www.motherboards.org and type in your motherboard, it will find it and give you all the information that you need.
Nov 08, 2009 | Cornerstone INTEL SE440BX-2 SLOT 1 PIII...
Intel desktop board SE440BX-2
Intel don't do an xp driver for this board. It may be worth downloading and trying the NT driver from www.intel.com
Jul 25, 2009 | Intel Desktop Board SE440BX-2 Motherboard
Sound Problem for SE440BX-2 in XP OS
You can download the driver here :
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=208&DwnldID=3522&lang=eng
Mar 20, 2009 | Intel Desktop Board SE440BX-2 Motherboard
I have an intel SE440BX-2 that does not recognize my mouse and keyboard. The scroll lock, num lock, and caps lock all flash repeatedly. The keyboard and mouse do not work at all. Tried 2 different hard...
hi im josh in cebu.friend if it wnt detect the probem is on your bios setup or on your motherboard parts like the cmos batt. you go to bios setup then go to pheriperals then choose enabled keyboard and mouse. or try to remove your cmos batt then afterr several seconds.install back firmly and tightenly. then reboot your pc.this will help you a lot good luck
Feb 23, 2009 | Intel Desktop Board SE440BX-2 Motherboard
BIOS for SE440BX-2 Mothermoard
How do you mean corrupted is it because windows will not start or upgrade
I would say your BIOS is Ok
you just have to try to reinstall windows but use full version not an upgrade one
Aug 23, 2008 | Intel Motherboard
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
yes, i think that this will be optimal. rember after some dvd burn to
defrag your hard disk
Sergio
Mar 14, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Processor up grade
The fastest cpu you can use on your mb is a pentium 3 800. Providing that you have the latest bios update.
check this link here.
You may need to download and install bios update from factory website .
Feb 22, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Agp issues
Do you have another video card to try? If so try it. But it sound like something is not seated correctly. Please respond back. Also do you have a built on video card for this board?
Feb 12, 2008 | Intel Desktop Board D850EMV2 Motherboard
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
