Question about Quinny BUZZ 3 Capri Stroller
Cant assemble quinny buzz lost the manual
My buzz was damaged at the airport and I had it repaired. It has come back in bits and needs to be reassembled. I cant fine the manual for love nor money. Can you help me please?
Ok I'll try my best,
1. Fix the fron wheel to the frame by sliding up until it locks.
2. Attatch the back whhels by inserting them and pressing the buttons underneath to lock them in.
3. Unhook the string to pop up the buzz
4. Clip in the seat
And thats it!! Hope this has helped!
Posted on Feb 18, 2009
Quinny buzz clip to open missing
Hi Ellen
The transport clip is a safety measure to ensure the chassis remains closed in transit - like when it's in your car boot, to make sure it doesn't unfold while you're driving. It is available as a spare part item, RRP 10GBP (full info can be found on our Note for Buzz spares)
The click noise you hear when you unfold the chassis is not related to the fold lock. This is a safety measure designed to warn you not to continue forcing the chassis open as the locks are not completely disengaged ready for the chassis to be unfolded. By forcing beyond this noise you may cause damage to the fold / unfold mechanism. If you hear the click, allow the chassis to fold again and try again. Ensure the button is fully depressed / the other side button is fully pulled forward before attempting to unfold again and you should not hear a click. If you do, it would be advised to book the chassis in for inspection & repair required.
Quinny Buzz Quinny Buzz Xtra Spare Parts
Repair Charges Effective Immediately
Mar 20, 2014 | Baby Gear
I have a 2008 Quinny Buzz stroller that we acquired for our expected baby. Trouble is, when we brought it home, we noticed that the seat is not sturdy and is shaky. We've pulled it out and have tried...
Best of luck on your little one's arrival!
The page for your stroller has the instruction manual, which may be of some help:
http://www.quinny.com/ot-en/strollers/urban-use/buzz-3
Or you could call 877-746-7178.
Good luck, and I hope this helps!
Jul 01, 2011 | Quinny Buzz 3 Stroller
I cant discover how to fold my quinny buzz 3 and how to lay and sit the seat up
hi here iis the manual
http://www.quinny.com/media/producthandleidingen/Quinny/manual_buzz3_2010-1.pdf
you may also find this video useful
http://www.youtube.com/watch?v=-3niAfNKed8&feature=related
Nov 02, 2010 | Quinny Buzz Jogger
The handlebar adjustment cable in our quinny buzz has snapped - can you buy (and install) a replacement cable
hi you have to get the handle bar assembly and they are easy to change
here is a video of how to change one for the mothercare my3/4 but its the same as the buzz
http://www.youtube.com/user/dorelengineers#p/a/u/1/viSDFutpAOY
which country are you in and i will try to get you a link to the handle part
Nov 01, 2010 | Quinny Buzz Three Wheel Stroller
Where can i get spares for my quinny buzz ive
Depends on where you are located. If your are in Australia, Karlisles Pram Fix can supply spare parts for the Quinny models and do repairs, there details can be found at www.karlisles.com.a
As for other countries, Quinny has authosied suppliers and repairs around the world, check there website for details.
Hope that helps
May 30, 2010 | Quinny ZAPP Stroller
How do i order a quinny buzz box/bag as mine has been lost at the airport?
im selling mine on kijj for 25.oo like new call me 647 997 6463 im in toronto
Apr 29, 2010 | Quinny Buzz Jogger
I have lost one off my quinny buzz 3 pop on back WHEEL
Found this on the last page of user manual
Front wheel assembly
Rear wheels
Rainshield
Bug net
Shopping basket
Car seat adapters
• XL Seat Pad
To order parts call (800) 951-4113.
Include the model number and manufacture date (found on the bottom rail of stroller) and a brief description of the part.
Aug 20, 2009 | Baby Gear
New ram for quinny buzz
Be sure it is the gas ram and not the cast aluminium anvil which the gas ram pushes against. The symtoms are similar
This 'L' shaped casting snapped in half on our Quinny Buzz and I managed to repair it by taking the whole centre hinge apart, drilling out the pin which holds one half of the aluminium anvil in place and removing this striaght piece of the anvil.
To repair I first glued the two parts together with araldite then held them in the vice whilst drilling through both pieces to a depth of about an inch with a 4mm tapping size drill. Then seperate the two parts, tap the shank out 4mm and drill the right angled bit 4mm clearance. Reconnect the two parts using a 4mm steel screw and some 'locktight'. Replace the anvil in its slot and replace the holding pin securing with araldite.
Reassemble the whole shooting match and it works ( well ours did....and still does!)
This seems to be a common problem but I could not find any spares. Also the holding pin for the anvil is not made to come out hence having to drill it out. So I doubt if any spares are available anyway.
Not easy and you need a few engineering tools to do the job. But much cheaper than a new frame assembly.
Jan 08, 2009 | Quinny Buzz Jogger
How do you change the inner tubes on the quinny buzz
I took the whole tyre off the alloy bit, then when I had fixed the inner tube pushed it back inside the tyre then put the silver alloy bit back on.
Oct 20, 2008 | Quinny Buzz Jogger
Quinny BUZZ 3 Capri Stroller Logo
569 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
